818R For Sale!
818R Sale Thread
PADI Master Scuba Diver Trainer, PADI TecRec Gas Blender Instructor, Operations Manager - DNS Diving, Grand Cayman
So it's gonna be a Turbo H6...
Hey, I just corrected the spelling of my name in your post! I didn't go in a post my secret fantasies like you did. No wonder you have to wear that ankle bracelet. Next time just use "e" as you know it so you won't have to do any spelling. Tee hee!
Wayne, what's your current plan in terms of mods to the engine and accessories (hoses, exhaust and whatnot around) to fit and use that GTX?
Head gaskets, valves, retainers, guides, higher flow head and/or IM, etc.
You said no internals at the moment if I recall.
You already modified the coolant lines.
Maybe you already did other adjustments?
It will have the turbo 6 in it...
Wayne, when's the new site gonna be up with all of your VCP's??
http://www.25tires.com
^^^The car doesn't have a top. What's A/C going to do for you?
Rebuilding a web site sucks, the program I used to make it originally is no longer functional. But I'm almost done!
Here's a sale page http://thefactoryfiveforum.com/showt...952#post115952
Maybe use something out of an EV car or this ??....http://www.grassrootsev.com/airconditioner.htm
I wouldn't want an AC pump on the motor with piping
Put it in the front next to the batt & add a little weight on the front axel
or move to Calif where the taxes & politicians are way to high.
One thing you got going is the motor is in the back, not like the roadster, 33, coupe- no forced heat into the cockpit
Right, so these are height adjustable, seems to. I didn't know that. I like the wing cuz it fits lower on the car, but I don't want a small lip on the rear trunk either. A low big wing is nice. Only thing is not sure how aerodynamically efficient they (low big wings) would be since AFAIK only the big FFR R wing and the new FFR S wing (I haven't see yet) have been flow tested.
A knockoff carbon fiber Subaru s202 wing is easily and inexpensively obtained. Not as good at making down force as the aggressive Apr wings but is functional.
Yeah but to put some down force the entire car needs to flow air onto the wing.
If FFR tested their S wing and will offer it, what tells us a, say, APR GTC 200 wing would be better or worse in terms of down force, drag, top speed, etc.?
Actually, that may not be the thread to discuss about this. But anyway I am throwing out the question.
Any fitment issues with the 18x9.5 +40 on the rear? That is the same specs as the wheel I am looking at. Thanks
Got to see this amazing work in progress.today. Can't wait to see how it turns out.
2003 WRX - Daily Driver/Rallycross Beater
1998 M3 - Track Toy
Still trying to find a FFR car I fit in
Maybe I've missed it, but did you mention your tire sizes yet Wayne? If your fitting a 9.5" rear tire, I'll be ordering those trailing arms for sure. Very excited to see your new setup on the dyno, and while your stand alone is more expensive than some others, I might be persuaded when the time comes just cause you support the community. Do you do remote tuning?
I'm running 17x8 fronts and 18x9.5 rear wheels with 235/40/17 and 265/35/18 tires
+45 front and rear. I'm using a 5mm spacer in the rear.
Is that +45 in the rear with or without the 5mm spacer?
How's the body work coming?
Bodywork is all done, should be painted by the end of next week. It's going to look AWESOME!!!!!!
