RLTCS for '33 Hot-Rod
Look here for more info. Most people decide to put a 8 cyl engine in their, roadster, coupe, GTM, or '33 and RaceLogic Traction-Control Systems makes TC systems specifically for 8 cyl engines. The systems range from $1,100 to $1,300:
- RLTC8ALD (ATC 8 C+LC+DL)
- RLTC8ALDW (ATC 8 Cyl+LC+DL (TCWSSSET required))
- RLTC8DIA (ATC 8 Cyl+LC+DL+DA)
- RLTC8DIAW (ATC 8 Cyl+LC+DL+DA (TCWSSSET required))
The TCWSSSET are a set of 4 wheel speed senors if your donor didn't have any abs senors or you chose not to include them on your build. There is currently a group-buy going on (see above link) in the 818 sub-forum for a RLTC system. If you think you need to have ordered an 818 to get on of their systems/add-on(s) then you're wrong. It's open to all builders. The above prices are without the discount applied, once applied, it bumps the $1,100 price down to $750 (around due to the always changing exchange rate between pounds and dollars) and the $1,300 price down to $880. If you check on the original thread there's more info (link above). Hope to see more people join!
Last bump
