38 offset is prob the lowest you can go before you rub the quarters. I will be running 18x9.5 38-45 offsetout back and 17x8 40-45 offset, rota, rays, enkis or something
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Darn right!!! I totally forgot about the 9".
Anyone knows the offset difference between 2 wheels that have 0.5" width difference in order to keep the center of the wheel at the exact same place?
I don't know if you understand why I mean.
Ok found this from someone here : http://www.1010tires.com/Tools/Wheel-Offset-Calculator
