Page 3 of 34 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 1358
Thread: RM1Sepex Build Thread
    Freeport, ME
    Wayne and Erik put the bushing above the bracket... That modifies the suspension geometry. You can do that if you use a spacer under the other leg, it is about 1/4 thick. If you don't use a spacer when you tighten it you will distort the aluminum bushing housing, not a good thing to do to aluminum, when aluminum fails it cracks, a dangerous condition IMHO and Tony's as well.
    They did a bunch of work to develop a high performance design, I'll make mine correct. Only the early cars will have the issue, I'm not aware of what chassis number will start getting the modified bracket, mine is #17
    Huntsville, Al
    I measured out the change in geometry when I mounted the bracket on top (with spacers) and emailed the difference to Jim...end result was it was in the noise...road test will verify...good catch and I am glad they are fixing it.
    Freeport, ME
    I didn't want to dig out my old books and figure it out... 1/4 in across the 14 inches or so between the pivots isn't very much. I just figured that it should work as designed and poked and measured, discussed with a friend etc... our first soln was spacers and I even have a very nicely machined set in aluminum... LOL
    I was more concerned with someone with the shorter wagon arms... the bushings can't reach those other holes if placed on top
    Huntsville, Al
    Yeah 10-4.. Good call.
    Senior Member Stickshift84's Avatar
    Rhode Island
    Well, I just swapped the ends on my control arms (wagon/steel) and they do work. I had to trim a little of the upper bracket on the frame to get them in but they fit and will be located correctly to the manual. Lower on top of bracket and upper under bracket.
    Mechie3's Avatar
    You guys are talking about trimming the piece of steel bent under the mounting tab on the frame? I just tried putting the passenger side in as described (top is under, bottom is over). The bolt hole doesn't line up like RM1 noted on the bottom hole.
    Stickshift: When you swapped them, is the leg with the bump on the bottom like the manual first describes to swap them?
    What nuts are you using to bolt this together? I measured the bolts to be M14 x 1.5, but don't see that on the hardware list. Is there a different nut that came with the donor?
    Zero Decibel Motorsports
  7. #87
    Exeter R.I
    Mechie I used m14 Subaru bolts and nuts, and I have ordered two more. As of right now I put 1/4''spacer under the inner leg, but I will mod the frame gussets to accommodate the bushing to fit under and over like recommend, also I am going to get some high grade chassis paint for touch ups.
    Btw, my headers only cleared the drivers side engine mount by a tenth and I had to finagle them in to fit. I am going to trim that back a bit to ensure clearance under load. See Dan you have brought it back out in me!! Lol
  8. #88
    Same. I'm going to have to trim the tab and re-drill some holes. Not sure if I want to drill into the frame brackets, or just widen out the bushing holes. Probably the latter.
  9. #89
    Freeport, ME
    Mechie
    see the pictures, post 73
    bushing bump on bottom
    yes remove the vertical tab around 1/2 inch should do it on the left
    factory bolts
    Dan
  10. #90
    Could you post a picture of what it looks like after you fix the control arm problem? Thanks.
  11. #91
    Mechie3's Avatar
    factory bolts
    Dan
    I'm using factory bolts, but the OEM setup screws into threaded holes on the car so I don't have nuts to go with my bolts and wasn't sure what nut you were using with the bolt.
  12. #92
    I'm going to take a bolt to Lowe's and find a nut for it.
  13. #93
    Mechie3's Avatar
    Ok, thanks. Was trying to figure out if I was missing something (physically or mentally). lol.
  14. #94
    Freeport, ME
    Bolts and nuts: I didn't pair mine up when removed... I used a bucket and reconditioned everything. So I'll need the nuts later! :-)
    Control arm issue. I just fit both of mine...
    Right side had to adjust the hole location about 3/8 inch towards the outside of the car, see sharpie markup on bushing
    on the left side once I removed the vertical section about 1/2 and applied some Hyd force I was able to get my busing in place. The hole movement does not allow modifying the bushing. It will be too close to the side edge of the bushing. I need to dig out a die grinder and modify the steel mounting hole.
  15. #95
    Freeport, ME
    Finished!
    I ended up using my small air powered cut off tool (3 inch) and my air die grinder with one of those nasty tips like you use to port an engine
    I just need to get a couple of replacement bolts... and I can button up the front suspension
    I've included a shot of my powder coated front firewall.
    You need to grind the LCA stud that goes through that left LCA bushing to clear the firewall. I took it back to the nut using a drum sander
  16. #96
    Clovis, Ca
    I wonder which chassis #'s will start having the fix.
    Thanks- Chad
  17. #97
    Freeport, ME
    Found the place I stole them from, the rear strut bolts, time to get some nuts! :-)
  18. #98
    Clovis, Ca
    Not trying to be an A$$, but did you see that your front control arm bolts are in different spots in picture 3 of 5? Just looking out for ya buddy!
    Thanks- Chad
  19. #99
    Mechie3's Avatar
    So, summary, to make sure I've followed right:
    Passenger side: Slot aluminum bushing bracket, trim gusset as required.
    Driver side: Slot steel bracket, trim gusset as required.
    So you robbed Peter to pay paul, and now Peter wants to be paid back with some M14 nuts. I'll have to see if i can find any lying around.
  20. #100
    Freeport, ME
    OOPs brain fart when I tossed it back together to get the photo! Corrected it above (crudely I must add!)
    I didn't need to trim the brace on the passenger side...
    Mechie3 I'm using adj rear lower transverse links, can you give me the center to center distance of stock links? I need a starting point as I bolt that stuff together...
  21. #101
    Mechie3's Avatar
    What's it worth to you?
    We have a nifty hole centerline measuring caliper (uses cones to self center). I'll borrow it tonight and measure the links at home.
  22. #102
    Freeport, ME
    I'm having problems fitting the passenger footwell/dead pedal, anyone have a solution?
  23. #103
    Good job man. I just spent a little over an hour cutting and grinding my driver side mounts. Looks like mine are misaligned in a different way than yours. Mine fit underneath but are angled. To get them straight I have to trim back that tab that hangs down. I'm afraid to cut too much of it off in case it has some structural properties to it. I decided to stop cutting the chassis when I got to my 3rd beer.
  24. #104
    Mechie3's Avatar
    A rubber mallet. I installed the side panels starting from the rear, then the front one, then placed the dead pedal, and then the upper panel that goes over it. I also too the small 90 deg flange and bent it a little farther (don't remember which direction, it's at the powder coaters right now). I did take a few light taps from the mallet to get it in position. I then started at the top of the small right angle flange, drilled, cleco'd, then, pushing in really hard, did the next hole down. Eventually it all lined up so I could drill the bottom flange on the floor pan. I then did the upper panel, and then the joint between the two.
    Spacing on the rear lateral links is about 16.25". I left the calipers at work (doh!) and used a tape measure.
  25. #105
    Freeport, ME
    I played with it like that too but started having it pop the floor down like an oil can... It looks like it would fit fine if the firewall was back about 1/2 inch... I'm not coating those so I put it off until later. I figure everything inside the car will be covered with fatmat and either carpet or foam and vinyl. My garage is a bit of a mess right now... I couldn't find that rubber mallet today!
    Thanks for the measurement. I just needed an approximate starting point...
    The LCA issue still has me a bit worried, who knows how the tolerances have added up and how straight our front ends will be? If those brackets move side to side 3/8 of an inch our front wheels can be moved accordingly and we could have some fender centering issues. I understand that can happen with some of their other vehicles... my confidence is shaken I guess! I made up my own chassis and jig for my reverse trike... getting it straight and square was a real PITA Who knows how straight our parts are too?
    Dan
  26. #106
    Exeter R.I
    I set up weld fixtures and weld all day so I know stuff still distorts no matter how you set it up, but from my measurements the actual chassis is very square at all corners and mounting points and I am confident we will be fine.
    Mechie, all my spacers are actually stainless, and like 4 are aluminum
  27. #107
    Mechie3's Avatar
    Hmm, maybe mine are stainless too. I didn't do the magnet check. The ones I machined were all within .005" (most right on) and the upper links were tight! I did have 1 aluminum one, which was odd. lol.
    I do remember the dead pedal frustrating me, but the second one was much easier. It did take a bit of "encouragament", but once it fit it's relatively easy to get it to fit again.
    Have either of you tried mounting the shifter yet?
  28. #108
    Senior Member Flamshackle's Avatar
    Aotearoa (New Zealand)
    You should be able to get specification measurements and cross check it very easily surely?
    It should be very simple to confirm if the chassis is flat and accurate.
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
  29. #109
    Exeter R.I
    More fun to come boys!!
    I am close to mounting the shifter, but had a snag, so I have to fix that first.
  30. #110
    Freeport, ME
    Everything I have checked looks pretty square, remember you are measuring to welded areas etc... as Metal said with heat comes distortion... I plan on doing some more measurements today... It's my background as an engineer... find a problem, look for another! :-)
    Dan
  31. #111
    Freeport, ME
    Sadly I was correct... I messed up and elongated the wrong hole on my right aluminum bushing... my right wheel would have been almost 3/8 behind my left wheel
    My methodology:
    It is almost impossible to choose what to use as a reference, my aluminum is on the front so here goes...
    I set the control arms level and found the closest front frame ref at a level. It just happened to be at the same height as the top of the LCA bushing bracket. I put a piece of masking tape there for an easy to find mark.
    On the control arm end I found that the machined face behind the ball joint mount aligned with the measuring tape
    My measurement on the left side is 14 1/2 inches (can't discern past this level due to lack of hard measuring points) remember this mounting point was slotted for a bracket that was mounted too far forward, that is why we cut the vertical part of the mount.
    On the right side I was short by almost 3/8 of an inch! I had modified the lower mounting hole in the right LCA bushing. That swings the ball joint rearward, rotating the virtual triangle. I located my original mods based on minimizing bushing stress. Any slight misalignment of the front LCA mounting hole, even a small amount, moves the rear mount. My slotting of the rear inner hole made the dimension shorter than the other side where the mount was modified fore and aft.
    When I readjust the bushing to use the correct hole location on the right lower LCA bushing, I get 14 1/2 inches.
    So we need to all make sure that we adjust properly.
    My next question is what is the correct dimension to put the wheel in the center of the wheel well, time to contact Tony again!
    Dan
  32. #112
    Exeter R.I
    Dan find center of the frame front and rear and measure to mount points, than from those points you can determine were the arms front and rear will reside. Sat i am re -intallimg my arms and will document.
  33. #113
    Freeport, ME
    my measurements show that the lower mount holes are correct/symetrical... the uppers are much harder to determine...
    Dan
  34. #114
    Mechie3's Avatar
    I'm just going to let you guys figure this one out.
  35. #115
    Freeport, ME
    I am stupid
    put a broom handle across the front of the car, it nestles right in to the frame and brackets. The aluminum tabs for the sway bar links are less than 1/4 inch away! Easy to set the arms perfectly in line... just hold them when the distance is correct and tighten the bolts. Now what is the correct distance for easy, even alignment in the wheel wells?
    Eric, you just put the body on can you check your arm location(s)?
    Dan
  36. #116
    Huntsville, Al
    Not sure how you want me to measure, I have a ton of stuff in the way like all the coolant lines...
  37. #117
    Exeter R.I
    When it comes time nick and I will post a thread on the alignment
  38. #118
    Freeport, ME
    I'll ask you a different way:when you bolted up your LCAs you slid your front mount up into the forward mount and seated the rear mount above the outer frame bracket. You insert the front bolt and manipulate the rears to line up the holes. You put a spacer under the inside rear mount. Insert bolts and torque them down. How did you determine where to tighten down the rear mount? How did you make sure that the other side was at the same place? Since this location makes a big difference in where the actual center of the spindle ends up and where the wheel ends up in the eventual body location what is the optimum location?
    I was looking at it today and noticed that the steering rack mounts make a perfect place to put a straight edge across the front of the car. I can adjust the rear mounts a bit and get both sides to locate the tab for the sway bar linkage on my aluminum arms a smidge under 1/4 inch behind the line made by the broomstick, the line made by the front of the 818 and the LCA mounts.
    I'll ask Factory Five what the design's nominal location is to center the tires. Builders can then use this simple trick to get them in the correct position every time.
    Since you just got your body on, can you use something to check on your car... even a 3 foot section of 1/4 round bar stock slid in could be used to get an idea of where your wheels are.
    I'll add a photo tomorrow but I think it is pretty easy to visualize...
    Dan
  39. #119
    Sep 2011
    NH
    What about centering the steering wheel and then using a laser level on the rotors (use a 2x4 for a spacer) to go back to a board mounted to the rear mounting bracket. Compair measurements.
    Just an idea.
  40. #120
    Huntsville, Al
    umm... I didn't measure or check anything.... simply put it in added required spacers so there was little to no stress on the arms and torqued them down. The fit of the bolt relative to the mount isn't a machined fit to begin with... Front initial alignment is at 3* caster, -0.5 camber with 5 inch ride height (too high!) wheels are centered to the naked eye in the wheel well opening, however the side sail positioning and squaring of the nose and fenders will really determine how it all "looks"... my locost 7 was off 1/16 -1/4 in total square from front to back which made the front suspension off "slightly", like 1/4- 5/16 off relative from left to right...I thought it was going to be a huge deal at the track...I couldn't tell... not saying it wasn't wrong then or that I was wrong for not ensuring that the left and right arms are totally square....I honestly didn't see it being a huge issue if it is off "slightly" since the alignment will ultimately determine how it drives (flame on here as you want).... I would measure it the way you did for comparison ,but between the coolant lines, sway bar end links, all the radiator aluminum and wheel well aluminum being in...I don't think I can give you an apples to apples measurement....not sure what to say...my overall angle of the control arm at the level position is 1* pitch up because of the whiteline bushings...after speaking wit Jim this ended up being in the "noise" and his ultimate answer was, see how it feels under braking...good enough for me...I flown way more screwed up helicopters in combat as a maintenance test pilot doing recoveries....so with a head nod from Jim I moved on...not saying I won't be back here asking you later how you fixed yours...lol...but I am ready for my first safe drive!
