Page 11 of 34 FirstFirst ... 91011121321 ... LastLast
Results 401 to 440 of 1358
Thread: RM1Sepex Build Thread
  1. #401
    Encinitas, CA
    Bob, was the root cause that the early chassis wagon LCA holes were off? Or that the wagon rack isn't wide enough? I just got my kit (and have a wagon donor), so is it safe to assume this has been addressed in the chassis or will I need longer tie rods?
    Lee
  2. #402
    Freeport, ME
    mine is a sedan, WRX
    bottom line, my rough measurements indicate that the rack is mounted about 3/4 of an inch too far to the left.
    Pull off your rack bellows, center the rack
    the pivots are waaaaay different from side to side!
  3. #403
    Lee
    On my car, the functional center of the steering rack was not in the center of the car.
    On newer frames, the LCA holes were moved in so the tie rods would reach. I don't know if the steering rack mounting was changed.
    Freeport, ME
    Eric, Craig, can you check your cars? I think that we need revised brackets to shift our racks to the right about 3/4 to have both sides even. I'd expect bump steer due to the misalignment of the pivots!
  5. #405
    Mechie3's Avatar
    One more thing to fix I guess. hopefully it's not too involved.
    I'll check mine tonight if Vball/dinner allow time.
  6. #406
    Exeter R.I
    I will double check my setup, but my rack seems to be lining up correctly alignment wise. I just centered the tie rods to the frame and centered the wheel and it seems pretty close lock to lock. I will do a closer assessment soon to get an official readout,, new wheels in mail so a go pro test drive is coming
  7. #407
    Mechie3's Avatar
    Mine is off. Not sure by how much. The driver side boot is quite compressed while the other boot was rather stretched with the wheels both facing forward.
  8. #408
    This is how I moved mine over. It still needs to move over another 1/8"
    The rack they used on the original chassis is much longer on the passinger side.
    I don't know what that is off of.
    compared to my rack
    I thought the issue was because my rack is from a wagon.
    I bought a sedan rack on ebay and it has the same issue.
  9. #409
    That is compressed! That is compressed a lot.
  10. #410
    Freeport, ME
    so... after printing out the wiring diagram and using my netbook to use Craig's beautiful wiring guide with photos of the connectors... I found that there are two 2 wire connectors to the clutch pedal and I had only extended and hooked up one... the one I can't find on the wiring diagram! So after pizza and some wire extending I was in business.
    I took my starter off, PB blasted the bendix area and manually cycled it a few times.
    viola, turn the key, the starter engages! The fuel pump cranks up etc...
    BUT because of the stupid steering rack issue I removed my lower water hose so I didn't fill her with anti freeze/water and couldn't crank her and attempt my first start!
    Close!
    Unrelated issue: when I hook up my battery the gauge cluster displays the ODO reading... is it supposed to do that without the key inserted? most electronic dash displays don't. If not ideas on where to look?
    EDIT: just had to read farther down Craig's wiring thread! The cruise clutch switch... :-)
  11. #411
    Just check my sons 06 NA wagon. The odometer reads with key off.
    It is an LCD screen, so the drain on the battery would be very low.
    Freeport, ME
    awesome! :-)
    how far did you "shift" your rack Bob? I'm thinking 3/4 would get it close to centered... I really need to get the coolant in so I can twist the key and attempt to start her...
  13. #413
    awesome! :-)
    I think after you get all your camber, caster, and toe set you will only need about 1/2"
    All my alignment has been done with string and a harbor freight digital level.
  14. #414
    Freeport, ME
    sooo...
    best case is zero bump steer. This results when the rack pivots line up with a line made by through the upper and lower A arm pivots (ref Chassis Engineering, Herb Adams)
    4 solutions, listed from worst to best (IMO)
    1: extend the inner tie rod on the right side, simply cut rod, slide extension tube over the cut portion, re-weld. this yields zero bump steer on the left when straight, maximizes the bump to the right. NOTE: I have not removed the shock/spring to measure how much bump steer exists
    2: cheat the position of the rack, it won't be in the center when straight (Factory Five's current soln.) You equalize the bump steer in each direction but turning radius varies because there are more turns to lock in one direction vs the other
    I've went through all of the build threads, every existing car shows a compressed bellows on the left and extended on the right when straight.
    erik's
    metalmaker's
    wayne's
    3: shift the rack to the right to place the rack in the center of the car, equalizes the bump steer to both sides, allows equal turning radius both ways, equal lock to lock on both sides (as per above) Bob can you do a simple measurement of bump steer for us with this solution?
    4: lengthen the rack slide. make a spacer that screws into the rack and has female threads on the other end so that the inner tie rod screws into it. I'm not sure if the bellows will stretch far enough... I'll be attempting this solution
  15. #415
    So that Chassis Engineering thing means that the bellows need to be extended the exact same amount on each side?
    And what if they are not like on those 3 builds? What should we except be the behavior on the road?
  16. #416
    Exeter R.I
    Don't feel the rack needs to be shifted, my wheels are lining up and my wheels are straight with sufficient thread on tie rods and lock to lock very close. Could it been done, yea, does it have to, not from what I am seeing, but a true laser alignment might shift my thoughts. Final assessment is for now it is ok, and should be ok.
  17. #417
    Encinitas, CA
    As Dan said "turning radius varies because there are more turns to lock in one direction vs the other" meaning that since the driver's side bellows is compressed more, you'll run out of rack travel earlier (and loose turning radius) making a right turn. It appears that tire/frame interference will probably be the limiting factor the other way (to the left).
  18. #418
    Freeport, ME
    I tore into it this morning
    Bob is correct it is very close to an inch, I got a final measurement of 1 1/8 inches
    I'll make up a 1 1/8 long spacer with a stud sticking out one side to screw into the rack and a hole threaded like the rack on the other end to screw in the inner tie rod end. Not sure of the thread yet, my local ACE only has 16 x 2.0 bolts and the threads are too course. Naturally I don't have such a large tap or die...
    I'd rather do that than shift the rack to split the difference. The current setup has the rack short on BOTH ends, the pivot points do not line up for zero bump steer, I think with our almost parallel control arms a favorable condition exists, I don't expect much bump steer. My engineer's brain won't let me live with different turning radius, side to side. LOL
    ref info
    http://www.longacreracing.com/articles/art.asp?ARTID=13
  19. #419
    Dan,
    What year rack are you using? Will this affect the 05+ guys with bolts on the driver side?
  20. #420
    Mechie3's Avatar
    I have an 06 rack with the bolt through holes on the driver side. My driver side bellows is compressed with the passener side popped off since I didn't re-clamp it on yet.
  21. #421
    Freeport, ME
    I have an 05 and an 06 with the cast in mounts on the pinion end. They are identical in all aspects
  22. #422
    Freeport, ME
    She started right up!!!!!!!
    BUT, I have a significant water leak under the motor... video will be forthcoming!
    2nd customer start with stock WRX wiring loom!
    Can you say PUMPED!!!!
  23. #423
    Encinitas, CA
    Congrats!
  24. #424
    NICE! how many warning lights on the cluster???
  25. #425
    Freeport, ME
    didn't notice how many lights
    I found fluid dribbling out of the gooseneck thermostat area under the car... I spilled some when filling it too so it isn't real clear. resealed it and added high temp RTV. I'm hoping I don't have a "deeper" leak as the water pump is in back of the timing belt cover in that area...
    I have the front shifter cables and the throttle cable to attach and I could go kart her... next week for sure
  26. #426
    great job Dan
  27. #427
    sooo...
    erik's
    metalmaker's
    wayne's
    Another option might be to find this steering rack used on the silver chassis. It is longer on the passenger side.
  28. #428
    I'll have to take some pictures straight on at the suspension and draw some lines.
    It will have to wait until next week. I'm leaving in a few minutes to go to VIR for my Ariel Atom driving experience (gift from wife). Then Sunday to Lexington, KY for an autocross. Then to Lake Cumberland to winterize camper and tow home the jet ski. All of this in my second donor car.
    Freeport, ME
    Brake, ABS and Airbag warning lights... the brake one is simple, I haven't plugged it into the master cyl
    http://www.youtube.com/watch?v=bxjcO...ature=youtu.be
  30. #430
    #winner
  31. #431
    Sep 2011
    NH
    Congrats!
  32. #432
    Exeter R.I
    For the abs you need to completely remove the entire wiring to the unit and cluster, airbag, take the bulb out, brake also goes to e brake wire .
  33. #433
    Freeport, ME
    good to know, the ebrake wire isn't hooked up either, all the abs hardware and wiring is gone don't know about abs to the cluster and I'll get to the bulb for the airbag, all of the airbag hardware and wiring is gone too. I have a bunch of un-needed relays to pull too
    like the rest of us now I need to button up a bunch of stuff to get it to go kart, for instance I found my ebrakes are dragging a bit and I'm having some issue with a hose to caliper connection in the left rear, I didn't extend the lights yet but I have no trust in their stated lengths as I have extra for my wipers and master cyl connections, didn't need an extension for the starter wire, my tail lights pretty much reach, etc..
    I need to do throttle and shifter cables to the front, ebrake handle and will jury rig the front rack stuff until I can get a spacer made.
    I'm vacillating as to getting it running with the stock kit provided exhaust vs jump to bell mouth 3 inch with a high flow cat and muffler. My wife thought it was pretty loud when I revved it up to 5000 rpm or so... just a catted downpipe right now
    Help:
    I'm having problems finding a replacement rack bellow/boot anyone have a source or want to mail me a good used one?
    just found my leak: Water pump to engine...
    UGH might be easiest to do if I pull the motor since I have to remove the timing belt and retime it...
  34. #434
    Mechie3's Avatar
    I think I have a boot off a rack I bought just to take apart and see the insides.
  35. #435
    Exeter R.I
    When you do pump, make sure to use a subaru rubber gasket, the gates one is junk paper. Abs something has to still be hooked up to illuminate cluster light. I guessing you tried the fuse?, if power is going to fuse to cluster, it might be that. Are you sure besides the huge chunk of abs wiring you got the black ground and red/white wire that runs through the harness to a power source /fuse relays and than cluster. Save the relays cause good to have if needed and not always cheap.
  36. #436
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Help:
    Rock Auto has them
  37. #437
    I just filled the hole in my cluster with black RTV to get rid of the abs and airbag led lights.
  38. #438
    Freeport, ME
    Chris, mine had a paper gasket...
    Wayne, Rock auto is out, can't/wont allow me to order...
  39. #439
    Freeport, ME
    Bob when you get back do us a favor and measure the distance between the two inside front suspension pivots on the WRX you are driving and we can compare that to the 818... Did they make the 818 wider?
  40. #440
    Administrator
    Enterprise Alabama
    From a pure engineering stand point, you want the ball of the INNER tie rod to be at the same distance from the lower arm pivot on each side to have exactly the same bump steer. How the threaded part and bellows look at that point is secondary to moot. Now in the real world, you are going to want your steering wheel straight so unless you have you steering shaft splines index cut for YOUR car it's not going to happen. On both the cars I finished and drove neither had any offset worth mentioning. I had the outer tie rods off the spindles, turned the rack to one end, marked the wheel, turned and counted to the other end, turned the rack back to the middle, disconnected the shaft universal, rotated the wheel to straight up and down, reconnected the universal, hooked up the spindles and set the toe. So if the rack is off center, why not center the inner ball joints in relation to the frame/lower control arm pivot axis and center the steering wheel, attach steering U-joint and call it good? Worst case is you have slightly more turning radius on one side vs the other and not parts to fabricate.
