Results 1 to 3 of 3
Thread: Problem tightening Tie Rod end
    Jun 2012
    CrossRoads, Pa.
    Question Problem tightening Tie Rod end
    I'm trying to tighten the self locking nuts where the Tie rod connects with the spindle; after the nut gets up to the self locking ring, the bolt just turns instead of tightening the nut. Is there an easy way to stop the ball joint/bolt from turning so I can tighten the nut?
    thanks in advance,
    Nevin
    Pinch the tierod end in the socket with a large pliers. That should give you the needed friction. I used and impact wrench as well.
    Jun 2012
    CrossRoads, Pa.
    Thanks, I figured it out, I took one of the lug nuts, which are the same size and thread as the Tie Rod end bolt, and since it is not a lock nut it threaded on very easy up to the connection with the Tie rod end, then torqued it down to draw the cone of the ball joint/bolt into the spindle connector, then took this nut off easily and then the lock nut went on with out spinning the ball joint/bolt.
    Nevin
