818 builder
Yokohama s drives,good grip with 20psi 255/35/r18 rears,low- moderate wheel spin, temperature dependent. 60 degrees plus recommended.
The box is a 02 wrx:
Manual transmission gear ratios:
1st - 3.454
2nd - 1.947
3rd - 1.366
4th - 0.972
5th - 0.738
reverse - 3.333
final drive ratio - 3.90
