Results 1 to 5 of 5
Thread: Motor mount fitment LS3 2013 Camaro crate motor?
    Aug 2013
    Phoenix
    Hi guys, looking for info on motor mount brackets for LS3 2013 Camaro crate motor. Left side from C5 fits fine, passenger side not so much... Anyone run into this yet? Any help appreciated in advance
    Banned
    Aug 2011
    what's the fitment issue? pics?
    Clarksville, MD
    I couldn't get the new style motor mounts to work with my LS3 with Kooks headers. The rubber portion was nearly in contact with the header pipes. I ended up using the Pfadt mounts - much smaller, and more solid. Here's a link to my write-up.
    http://rumrunnergtm.weebly.com/engine-mounts.html
    I haven't updated my site in probably 2 years, but at least that section is accurate.
    I also had to go with the older style C5 motor mount brackets. The newer version that came with my LS3 interfered with my AC compressor with it mounted low to the passenger side.
    - Michael
    Member kabacj's Avatar
    Long Island
    Be sure you did not mount them backwards. If i remember correctly the way they look like they should fit , only works for one side. Flip them around. I am pretty sure I made that mistake using the c5 brackets on the LS3
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
    Fitzgerald Georgia
    The rubber mounts are very close to the Kooks pipes. I have the LS3/480 motor. Attached is what I did to help protect the mounts. They are made from Stainless Steel. .032 I think, easy to form. Hope that helps. DonHPIM0675 (1024x771).jpgHPIM0674 (1024x771).jpg
    Finished the car mid March 2013. What a car!!!
