Page 1 of 3 123 LastLast
Results 1 to 40 of 94
Thread: Lets talk about aftermarket suspension parts
    I would like to use as little of the rusty old WRX supension parts as possible. I have STI uprights and spindles, STI brakes and aluminum front control arms. What else do I need for the front? What aftermarket stuff do I need to complete the back?
    Thanks Mike
    Member 508wrx's Avatar
    Nov 2012
    Taunton, Ma
    You might be just about all set with the front. The rear you'll need the uprights, spindles, multilink, and trailing arms.
    The uprights and spindles can probably be found at rockauto.com or if your want to go sti you can do that as well (it will make fitting those rear brembo's much easier). As for the multilink and trailing arms you can do oem, sti, or aftermarket. I have no experience with aftermarket items in that area so I can't recommend a good place to start.
    A side note: If you use wrx style rear uprights you'll need an adapter kit to be able to use brembo's with those uprights.
    Mechie3's Avatar
    Indianapolis
    STI uprights don't currently work with the front suspension adapters. You'll need to make your own or machine down the width of the mounting point on the spindles/knuckle.
    For the rear, don't get STI lateral links. They're expensive as it's the only aluminum set for both of teh rear links. We don't have a rear swaybar, so you can actually use two sets of the 06 WRX lateral link. A few other years had the aluminum link as well, just don't know offhand. These don't have sway bar tabs, but this won't affect us. Both metalmaker and I went this route with dual aluminum links in the rear.
    You can buy cheap trailing arms and lateral links, but they tend to rust up pretty quickly.
    Zero Decibel Motorsports
    Check out my new website!
    QC, Canada
    I think Wayne has built some trailing arms that I think he planned on offering at some point... just saying, if anyone (or him) can confirm.
    At the same time I'm subscribing to this thread as I want to follow this up (and increase my budget I guess).
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    I already have the uprights and brakes for all four corners. So the front is all set with the exception of the fitment problem? Should be an easy fix. I will need 4 of the aluminum 06 lateral links for the rear? What about the lower cotrol arm in the rear?
    Thanks Mike
    Mechie3's Avatar
    Indianapolis
    Do you mean the trailing arm? You can get some OEM ones with pillowball bearings installed, or some aftermarket. There aren't that many. Cusco makes some. Others are generally knockoffs of that general design.
    Lateral links: Yes, you'll need 4 total. Cars only came with 2 at most. Some are $60/set on ebay. I got lucky and found a set for $20 (and had a set on my 06). I think 05's and 07's had them too, but not 100% sure.
    is this what i want 4 of? are they all the same length?
    http://www.ebay.com/itm/Subaru-Impre...r#ht_606wt_651
    Mechie3's Avatar
    Indianapolis
    Yes, that is the aluminum OEM link and they are the same length.
    Here's a pair for $60 ($10 cheaper per link than the auction you posted)
    http://www.ebay.com/itm/2006-SUBARU-...#ht_2801wt_826
    Full aftermarket set for $70 (used). Not sure of brand or quality. Looks like they were taken off a car at a junkyard.
    http://www.ebay.com/itm/Subaru-Impre...#ht_1240wt_959
    Freeport, ME
    my 05 had aluminum fronts too (and bent steel rears!) I went the aftermarket route and sold my aluminum ones... that $70 set looks like they are in good condition at a fair price...
    Dan
    What $70.00 set. Oh the ones I just bought. Now to find 2 more.
    Mechie3's Avatar
    Indianapolis
    I think he meant the full set of aftermarket arms for $70.
    Clovis, Ca
    Does anyone know if the camber adjustment on the rear of the 818 will be enough (-2.5 to -3.5) using the stock Lateral Links? This is for my 818R. If not, I'm considering the Whiteline adjustable links, or the super ridiculous priced Cusco items.
    Thanks- Chad
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    You will be able to get plenty of camber, I have .8° neg camber and have plenty of adjustment left.
    QC, Canada
    Enough adjustments to do like this black Merc?
    http://www.youtube.com/watch?v=_r6ltUgtFWI
    looollllll
    Clovis, Ca
    Thanks Wayne. FYI- I'm still going to get that shifter and wilwood package from you. I got some 2003 rear knuckles and 2007 front so it works.
    Thanks- Chad
    Aug 2012
    Long Island
    Thanks Mike
    Yes you'll need to mill them thinner, and then weld and redrill the top mouting hole. But it sounds like you have all the pieces you need for the front.
    05s also have a pair of aluminum links.
    The rest of the parts are provided by FFR except for the trailing arms. I went with MSI ones. Pricey but they are beautiful and several lbs lighter than the stock pieces and should last a long time.
    Aug 2012
    Long Island
    Clovis, Ca
    What bushings are you going to use?
    Anyone have the part number handy for the 06 Aluminum Lateral Links?
    Thanks- Chad
    Aug 2012
    Long Island
    I have Turn In Concepts bushings for them, both front and rear, they offer 95 and 80 hardness, as well as bearings.
    I don't have PN for the aluminum link as most online OEM Subaru Shops don't list them for fear of god forbid, price shopping. Your local dealer will probably tell you, mine's still closed.
    Clovis, Ca
    Is that the 1" correction arm? Do we even need the 1" or 2" correction with the 818 Suspension design?
    Thanks- Chad
    Aug 2012
    Long Island
    Yes, I ordered the one inch (and plan or running the 818 at race height which is one inch lower than street so hopefully the geometry will be close enough)
    This is what I have:
    http://turninconcepts.com/product_in...oducts_id=1174
    Technically you don't need any correction, but the only ones MSI makes for factory ride height are their gravel ones. I spoke to Mark at MSI and he said he could make me a set of gravel ones without the extra bracing, but the tubing will still be thicker and slightly heavier. I'll know if the 1" correction will work soon enough.
    I have the measurements and can email you if you send me a pm me your address.
    Administrator
    Enterprise Alabama
    The 818 has mounting holes higher to lower the car 1" and leave the geometry unaffected.
    Clovis, Ca
    So if we use the higher holes, we should use stock geometry trailing arms, not ones that are modified. Correct?
    Thanks- Chad
    Freeport, ME
    yes... all the suspension holes are duplicated (longer front arms only) for lower ride height
    Dan
    Lower rear links
    Anybody know if the 818 rear suspension will have provision for toe adjustment? My donor lower rear links are both bent. I want to replace them and need to know if I should source some like the Truhart lateral arms with adjustment provision.
    Quote Originally Posted by tmoretta View Post
    The rear most lateral bar has a CAM bolt on the chassis end to adjust rear toe.
    Clovis, Ca
    I went ahead and bought the OEM SPT lateral links and SPT trailing arms. These have the spherical bearings (pillowball) installed on them. Not sure I will like the pinkish/red color, but that is easily fixed.
    There are tons of eBay parts that are much less, with shady performance, so I stuck with Subaru Performance Tuning parts. When I'm racing, I don't want a cheap EBay part to fail.....
    If you do the same, make sure to shop around with the Oem part numbers. I noticed a difference in prices.
    SPT Trailing arm: st2027055000
    SPT Lateral links: st202504s000. (Wrx)
    Double check on your own- for your year WRX.
    Thanks- Chad
    Aug 2012
    Long Island
    Good choice, the Cherry Blossom Pink looks good in real life. With the removable endlink mounts not installed you'll have a clean look. Plus you can sell them for a few bucks.
    As far as I know they are steel.
    You are smart to avoid the ebay stuff. bearings pull out, welds crack, steel turns to mush, etc etc.
    I can get the trailing arms for $310 shipped. LMK if you paid much more.
    Clovis, Ca
    I paid $349. That's a great a price.
    Thanks- Chad
    Any thoughts on a stiffer rear (now front) sway bar? I have both the OEM and a Whiteline 24mm sway bar. I'm thinking the OEM will be plenty and the stiffer Whiteline may create too much understeer. Any thoughts? I guess once I have it running I could swap them out and see which works better.
    Clovis, Ca
    Guns-
    At this stage it's probably too early to tell. Anyone know the size of bar on the 818R? I'm guessing stock.
    Can someone do me a favor? Could they measure the width of their sway bar, and the length of the arms? I don't have a stock one available. I'm thinking I can grab one from my sponsors and make it work, while not having all the crazy loops in it. It would be straight and clean. It may open up another market for them.
    Thanks- Chad
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    My Knowledgeable Subie FRiends,
    Can I get your thoughts on these: http://www.ebay.com/itm/6PC-REAR-LAT...c04bd4&vxp=mtr
    I've seen a couple different sellers/shops selling what look to be the same exact thing, and I need all these parts, so it seems like a decent deal. I like the look, and the adjustability, but I don't know if they are decent parts from a quality standpoint. I certainly don't want to use substandard parts. The OEM parts seem very expensive for what they are and look both a bit bland to me and they also not as strong. For those reasons I'm thinking aftermarket.
    Thanks for your help!
    Clovis, Ca
    Quote Originally Posted by Xusia View Post
    I saw those, and other copies. Price seems great, but I researched the Subi forums... Everyone said to stay away/they are junk.
    That's why I stuck with OEM.
    Thanks- Chad
    Aug 2012
    Long Island
    Guns I think that bar will be way too thick, though it will be cool to try it out and see.
    The 2002 WRX had the largest swaybar, 20mm, after that they all went to 17mm
    my donor is an 05, so if I needed a little more I would go for one of those, they are less than $100 new and should give you a little more stiffness.
    Chad, Bar looks to be about 42.75" legs are about 6", and about 5.5 to the bolt center
    Eugene, OR, USA
    I was worried those might have been the parts you saw. Any links to the posts you read about them?
    Any others have any experience at all with these?
    Suisun City, CA
    Wayne will be selling a lot of parts soon (may already). I would keep an eye on his website. I'm probably going to end up buying some of my aftermarket arms and AWIC kit from him.
    rori's Avatar
    Tulsa, OK
    If you're interested in selling those endlink mounts from your kit, I would be interested in them for my wagon. PM me if your willing to sell them. Thanks!
    This is from a stock 02 sedan 20mm rear bar:
    Between the eyelets is 42 1/4"
    From the middle of the bar to the middle of the eyelet is 7 3/4"
    Eugene, OR, USA
    Quote Originally Posted by JeromeS13 View Post
    I knew he was selling the trailing arms, but he told me was wasn't going to be selling lateral links because FFR had plans to do so. I just fear that if those links are OEM, they are going to more expensive than they really need to be.
    Clovis, Ca
    Thanks for the measurement guys. I think I can make something work, I talked to my friend. I'll know more once my 818R gets here in Oct.
    Specs- 22mm Hollow Bars (possibly 19mm too) which are extremely light, tons of adjustment, Bladed or normal arms. I may even be able to adapt cockpit adjustability (818R). Stay Tuned.
    Thanks- Chad
    Administrator
    Enterprise Alabama
    The smaller sway bars will probably be the way to go, the street car was a little loose with the splitter and no diffuser or spoiler. Add the spoiler and diffuser and the car had some understeer with the same front bar.
