0
0
'04 wrx part out
Pictures here: (I'm very sorry the pictures aren't embedded, The IMG codes pushed me well over the word limit).
http://s1279.photobucket.com/user/Om...Sale%20-%20Car
TD04L. No shaft play. $150.
Front and rear Cobb Sways, Perrin End links - $325
Stock rims, 4k miles of regular driving on the tires with receipt - $400
*Rims need sanding/painting*
Rear Seat: $130
Brakes: Front disks and all pads only have 4k miles on them(have receipts), Rear discs plus calipers are stock(as far as i know) $175 for everything.
Passenger Fender: Small crinkle, few scratches. $50
Full suspension. Cobb sport springs. NAPA OE struts(4k miles on struts with receipts). $400
rear axles, $100
Front doors, $200 for passenger, $175 for driver(mirror is broken)
Fuel Pump, $50
Alternator $35
Power steering pump, $60
gas, brake, clutch pedal assembly $100
starter, $25
TMIC, $50
tail light, $100
Front driver cv axle, $35
lamco boost gauge, $70
rear seat belts, $40
Keyless entry unit and keyfob, $25
Glove box, $30
Intake parts, $100 for all
Battery tray and hold down, $10
coolant tank, $15
turbo coolant tank, 30
Wiper arms, $20
hood scoop, $35
owners manual and maintenance book, $10
hood support rod, $15
Dash harness, $100
Dash assembly, $100
interior dash fuse box, $20
shifter trim + shift knob, $30
cup holder trim, $15
center console trim, $25
steering column trim, $25
coin holder, $5
hood hinges, $15
grab handles, $20
dome light, $15
center sun visor, $10
sun visors, $40
floor liner, $75
oem rear bumper cover, $100
trunk lid, $60
headlight turn signal switch, $25
ac controls, $30
gauge cluster trim, $10
temp control bezel, $15
heater blower motor, $40
ac core, 65
dash center trim, $30
dash clock, $30
wiper motor assembly, $30
wiper motor cover, $30
brake booster, $30
washer fluid bottle and motor, $40
third brake light, $20
map light, $10
cruise control motor, $30
cruise control module, $20
rear seat brace, $35
rear decklid carpet, $60
antenna module, $15
air bag control module, $40
ac compressor pulley/tensioner, $40
rear window defrost module, $15
brake fluid reservoir, $25
ABS Pump, $30
hood release latch, cable and mechanism, $30
steering knuckle, $25
steering column bar beam, $35
rear body wiring harness, $50
front chassis harness, $150
ECU, $125
clutch fluid reservoir, $25
power steering reservoir, $30
trunk hinges, $35
steering wheel/no airbag, $50
fuel tank ascending unit, $30
Rear door(for parts, dented), $35
PAssenger side skirt, $30
headliner, $75
trunk and gas release, $15
Random electronic modules/wiring
Random trim pieces, plastic/metal/rubber
Random hoses/lines
Transmission *SOLD*
Engine *SOLD*
Front Passenger CV Axle *SOLD*
Front Seats *SOLD*
Gauge cluster *SOLD*
Ignition Switch, Keys, Housing *SOLD*
AC Compressor *SOLD*
Clutch, Pressure Plate, Flywheel *SOLD*
Short Shifter *SOLD*
Door Cards *SOLD*
Rear Passenger Door *SOLD*
Steering wheel *SOLD*
Steering rack *SOLD*
Driver Headlight *SOLD*
Engine Bay fuse box and cover *SOLD*
It is located in Paonia, CO 81428.
Willing to ship.
Reply or call, text @ 97o-27o-oo22 if interested I will be happy to post more pictures talk with you about it.
Thanks everyone.
- You may not post replies
- You may not edit your posts
Forum Rules
