Results 1 to 3 of 3
Thread: '04 wrx part out
    May 2013
    '04 wrx part out
    Pictures here: (I'm very sorry the pictures aren't embedded, The IMG codes pushed me well over the word limit).
    http://s1279.photobucket.com/user/Om...Sale%20-%20Car
    TD04L. No shaft play. $150.
    Front and rear Cobb Sways, Perrin End links - $325
    Stock rims, 4k miles of regular driving on the tires with receipt - $400
    *Rims need sanding/painting*
    Rear Seat: $130
    Brakes: Front disks and all pads only have 4k miles on them(have receipts), Rear discs plus calipers are stock(as far as i know) $175 for everything.
    Passenger Fender: Small crinkle, few scratches. $50
    Full suspension. Cobb sport springs. NAPA OE struts(4k miles on struts with receipts). $400
    rear axles, $100
    Front doors, $200 for passenger, $175 for driver(mirror is broken)
    Fuel Pump, $50
    Alternator $35
    Power steering pump, $60
    gas, brake, clutch pedal assembly $100
    starter, $25
    TMIC, $50
    tail light, $100
    Front driver cv axle, $35
    lamco boost gauge, $70
    rear seat belts, $40
    Keyless entry unit and keyfob, $25
    Glove box, $30
    Intake parts, $100 for all
    Battery tray and hold down, $10
    coolant tank, $15
    turbo coolant tank, 30
    Wiper arms, $20
    hood scoop, $35
    owners manual and maintenance book, $10
    hood support rod, $15
    Dash harness, $100
    Dash assembly, $100
    interior dash fuse box, $20
    shifter trim + shift knob, $30
    cup holder trim, $15
    center console trim, $25
    steering column trim, $25
    coin holder, $5
    hood hinges, $15
    grab handles, $20
    dome light, $15
    center sun visor, $10
    sun visors, $40
    floor liner, $75
    oem rear bumper cover, $100
    trunk lid, $60
    headlight turn signal switch, $25
    ac controls, $30
    gauge cluster trim, $10
    temp control bezel, $15
    heater blower motor, $40
    ac core, 65
    dash center trim, $30
    dash clock, $30
    wiper motor assembly, $30
    wiper motor cover, $30
    brake booster, $30
    washer fluid bottle and motor, $40
    third brake light, $20
    map light, $10
    cruise control motor, $30
    cruise control module, $20
    rear seat brace, $35
    rear decklid carpet, $60
    antenna module, $15
    air bag control module, $40
    ac compressor pulley/tensioner, $40
    rear window defrost module, $15
    brake fluid reservoir, $25
    ABS Pump, $30
    hood release latch, cable and mechanism, $30
    steering knuckle, $25
    steering column bar beam, $35
    rear body wiring harness, $50
    front chassis harness, $150
    ECU, $125
    clutch fluid reservoir, $25
    power steering reservoir, $30
    trunk hinges, $35
    steering wheel/no airbag, $50
    fuel tank ascending unit, $30
    Rear door(for parts, dented), $35
    PAssenger side skirt, $30
    headliner, $75
    trunk and gas release, $15
    Random electronic modules/wiring
    Random trim pieces, plastic/metal/rubber
    Random hoses/lines
    Transmission *SOLD*
    Engine *SOLD*
    Front Passenger CV Axle *SOLD*
    Front Seats *SOLD*
    Gauge cluster *SOLD*
    Ignition Switch, Keys, Housing *SOLD*
    AC Compressor *SOLD*
    Clutch, Pressure Plate, Flywheel *SOLD*
    Short Shifter *SOLD*
    Door Cards *SOLD*
    Rear Passenger Door *SOLD*
    Steering wheel *SOLD*
    Steering rack *SOLD*
    Driver Headlight *SOLD*
    Engine Bay fuse box and cover *SOLD*
    It is located in Paonia, CO 81428.
    Willing to ship.
    Reply or call, text @ 97o-27o-oo22 if interested I will be happy to post more pictures talk with you about it.
    Thanks everyone.
    May 2013
    bump
    May 2013
    bumping
