I've seen all the comments going back and forth so I put a call into FFR this morning. As of today the recommended max tire size for the front is going to be 215/40/17, not 215/45/17. The right 215/45/17 will fit but I think it's more important to recognize the overall tire diameter as tires can be different. On average a 215/45/17 tire is 24.4 and that would clear however if you stay with a tire that is 24" in overall diameter with the appropriate offset, you'll have plenty of clearance. Anything larger than that and you could be rubbing. They will be correcting this in the manual. If this causes an issue, I'd wait to see what fixes may come out to take care of this instead of laying out all the frustration here in the forums. From experience I can say that as builders, we almost always find a way to figure this stuff out so stay positive and it will get it figured out.
