0
0
The back springs are almost vertical.
So 1" of wheel travel is 1" of spring travel.
The front spring is at an angle so 1" of wheel travel may only cause 3/4" of spring travel.
I'm just ball parking numbers without doing the geometry, but the effective spring weight to the wheel might be the same.
