Results 1 to 9 of 9
Thread: new exhaust project - teaser
    I'm starting on a new exhaust project, with 2.5" pipe and thrush mufflers. Have to stretch the pipe a bit to slide over the mufflers. Will be about 2" shorter than existing and hopefully be able to tuck into the body recess to avoid cobra bites. I ordered polished pre-bent ss pipe from Summit but it needs a lot of work. Will add a cross-over near the front and a 2-2.5" reducer at the front to connect to the existing headers.
    Regards, Mike
    Coupe 258, picked up Mar 11-06, The Jones build site
    Fort Lauderdale Fl.
    Damn.........that's nice!! you could sell those.
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Senior Member Fluge's Avatar
    Ontario
    Looks nice Mike...sounds like you have a plan. I think I am going to use what I have to get started but will look to changing things.
    Keep us posted.
    Marc
    It's just A Matter Of Time
    Marc
    FFR Coupe 434, 347ci, Power Brakes, SAI Mod, 3 link rear
    Senior Member Mike N's Avatar
    Mooresville NC
    They call that bent pipe polished? I don't think so. Looks like a great upgrade.
    Mike............
    yes, supposedly polished, mandrel marks and all. It will probably take longer to polish than it will to weld. I was feeling pretty good about my progress and then saw the under car exhaust and collector by HCP 65 Racer - now that's cool work
    Regards, Mike
    Gorham, ME
    Hey Mike,
    Is it still going to be a double side pipe or a single one?
    Aug 2011
    Toronto Ont. Canada
    looks great mike, they should work out better than the smaller original pipes.
    It will be a double pipe - I like the look of the originals on the coupe, so I'm intending to keep the appearance as much as possible. Eventually, I may consider new headers the same diameter however will use the original Hookers for now. The new pipe has double the cross-sectional area. I'm going to use a section of pipe perpendicular in the front to make a small cross-over H, which will support the front as well. Will use a similar rear mount to attach to the car.
    My baffles rattle so will try to screw them down. I also had these pipes ceramic coated but they are rusting through. Was expensive but obviously not a great job.
    I have noise readings for different configurations and will re-do them with the new pipes to compare, and record a drive-by with both so you can hear the difference.
    Regards, Mike
    Senior Member Rodster's Avatar
    Orange County, CA
    I like it! An elegant solution - very clean!
    Ordered Type 65 Complete Kit Aug 29, 2012 - The 50-50 $ale!
    Standard Width IRS; Halibrands - 17x9, 17x10.5
    Kit Arrived: Oct 9, 2012; Build Started: Oct 28, 2012
    WordPress: http://wayne-yoshida-kh6wz.com/
    LinkedIn: www.linkedin.com/in/waynetyoshida
    YouTube: http://www.youtube.com/user/kh6wz?feature=results_main
