10
65
View Poll Results: How to finish the mesh panels?
- Voters
- 57. You may not vote on this poll
Gloss Black
Unfinished Aluminum
Originally Posted by
mikeb75
Yay, have oil pressure!
Also had to replace the oil pressure transducer I added at the oil filter block. Go ebay garbage; transducer arrived dead - read 2.5 volts at 0 PSI. For now I have a 500 PSI transducer installed, which will be bad for correct resolution and scale, but at least it reads .5v at 0 PSI.
onward.
Mike,
Your ebay oil pressure transducer is probably good, but just put in the wrong application.
For example. A sensor that read minus 100 to plus 100 PSI would read 2.5 volts at 0 PSI.
