5
4
I made a boo boo. I noticed in some of the diagrams that shorting the door open switches would send a power source directly to ground. The diagram shows the switches being normally open. I assumed they were normally open in their free state. Turns out they're normally closed in their free state. The diagram showing it normally open implies the normal state is the door being shut. It makes it easier to delete the door chimes.
I think I'm 75% done documenting the harness itself. Still have a few connectors to document. Im up to over 400 wires that can be cut. Im going through everything and labeling optional deletes in case you want to leave things like door activated lights and noting where to cut a wire at a junction vs at a connector. At the same time, it eliminates the most amount of wire, not just connector ends.
