I have three questions, one of which I think I know the answer to:
Are the OEM injectors the high impedance type? (I believe the answer is yes)
Are the OEM ABS wheel speed sensors passive (magnetic inductive) or active (magneto resistive)?
Can the misfire detection be disabled when using the OEM ECU?
These are all requirements to use the RaceLogic Traction Control system.
