0
0
65 Coupe Chassis question vs original
I am looking at the Coupe as my next project after building a mk4 however I have a few questions. Note to self: if I build another MK4 I would go with a 6 speed manual with IRS - I would definitely stay with the Coyote.
I have researched the original coupe vs the FFR design and I think the original rear frame roll bar behind the seats uses 2 down angled down tubes that support the roll bar and are somewhat angled inward toward the trunk and the FFR frame has angled down tubes supporting the roll bar running along the perimeter of the frame with a cross tube supporting roll bar behind the seats.
The FFR genII coupe uses similar suspension points as the MK4 which is an improvement over the original however does the Gen II coupe also have the foot box improvements as the MK4?
Can the coupe experts list the improvements to the chassis of the gen II over gen I including similarities / improvements over the original. Does the body of the gen II represent a scanned version of an original as per the MK4?
Can a Coyote fit in the gen II coupe, 6 speed trans with IRS? Recommendation for trans ect welcome for this combo.
Thx for helping me understand the differences between the Gen II coupe be the original.
First Time Builder
Dave covers a lot of the changes to the Gen II coupe: http://www.youtube.com/watch?v=hI82zkRtVrs
Coyote? Yes, there are several being built now.
Scanned body from an original? no, the overall shape is the same as the Gen 1
- You may not post replies
- You may not edit your posts
Forum Rules
