Tracked May 27/July 26, 2017
Build Completed Winter 2021
Picked up the car a couple weeks ago and started tearing into it. Here are a few photos of what it looks like now.
Think I will try to replace the timing gears and belt first before i go tearing into the heads. Maybe I will get lucky and the valves wont be damaged (doubt it though). Sounds like if the valves did crash into one another i will just be doing a valve job and replacing all gaskets. No need to tear into the bottom end if the pistons are not damaged correct?
