Can I replace an engine w/o taking out the tranny or removing the radiator
In advance thanks
Vinnie
In advance thanks
Vinnie
Yes you can
Yes no problem , but would remove the rad you have to drain the fuild anyway and there are only two bolt holding it 1- gives you move room 2- do not take the chance of hitting it with the engine, I am sure you are also removing the hood. It took me about 1 1/2 hour to get mine out by myself. you can just unbolt the headers and leave them there do not have to undo the side pipes.
I put mine in the first time with the trans in and the hood on.
Chaz...
