64
146
View Poll Results: Startup with new ID1050x or previous EV14s?
- Voters
- 0. You may not vote on this poll
Frank818
I tested a solution to reduce exhaust smell in the cockpit. Following on Harley’s idea of fitting a full plastic glass around the rollbar, I thought maybe half a glass, up to the humps’ height, could still deliver some performance. I cut a cardboard piece, slid it between the humps and rollbar and tested it. It did help. Hard to tell how much and I need more tests. Also a bit less wind and swirls inside the cockpit, so I liked that solution.
Some had concerns that Harley’s full glass could reflect other cars’ headlights at night, but a half glass like this does not matter much.
Adam, after a while not pushing the engine it started to smell more. And when I pushing it, it was smelling even more. But after 2-3 passes of higher boost and mid-range RPMs, it cleared! It smells much less now even when cruising. Funny...
This is exactly what I was going to try, just a half glass bolted to the engine cover. Was sure if it’d be enough or if I’d have to come up a little higher then the humps.
Adam _____ Instagram @PopesProjects____
YouTube Channel
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
