Got it!!
Found the problem. Something I've never heard of before!
A cam gear slipping sideways.
It did ground a bit of soft alu from the right side cover, the chain was grounding on it, I found a bit of metal, but just 3 or 4 and looking with a light I couldn't find more.
Still I need to remove everything on that side, which means draining the coolant again. I think this will be my 10th time.
Now what collateral damages did this do? If the gear also slipped around the shaft, then my valve timing is wrong I could have a bent valve too.
There goes my summer for sure. I have so much frustration inside it is impossible to nail down a value on any human scale.
