Page 23 of 25 FirstFirst ... 132122232425 LastLast
Results 881 to 920 of 996
Thread: FFRSpec72 818R Build Seattle WA
  1. #881
    Sgt.Gator's Avatar
    Bend, Oregon
    Jeff and Tony check out this MR2 Spyder that Tucker Sheppy has built to race against us in ICSCC ST/SPU:
    At this point he's running NA and 175 WHP, about 2200 lbs (including driver). I can't wait to see what kind of times he runs. It might inspire me to get on with building an NA 818R at 2,000 lbs and 175 WHP!
    50 more build images at: https://www.facebook.com/DDPerforman...type=3&theater
    Owner: Colonel Red Racing
    818R ICSCC SPM
  2. #882
    south-central CT
    Too much metal in the dry sump tank oil when I drained it, so out comes engine as I want to keep the block. So don't know if I will get a replacement EJ207v7 and drop it in and rebuild the current one or just rebuild the current one. F*&^ !
    Sorry too, to hear about engine problems. A new SB is a quick fix but I wouldn't run the pistons (they are fairly heavy) and you still are working with sloppy factory tolerances. You might luck out and you might not.
    I've built a few Subaru racing engines now. I've done a lot of research and have talked to a number of engine builders with good reputations. I work with Kenny at Larry's in Groton, CT. They have an international reputation for machining of and building Subaru race engines. Kenny has a lot of years of experience specifically with Subaru engines and does work for many New England performance shops. I've also worked with Micah McMahan, an engineer for Roush-Yates, who designed the Badger and Honey Badger engines for TIC. I have one of his destroker engines.
    I guess I am building up a methodology, or approach to building engines. This, based on everything that has come before and the fact that I have yet to spin a rod bearing nor have had an oil-related failure.
    Of most recent note is that I am building an engine for a DD play car and something that could hit the track in a pinch. I was going through several cases I have on hand. I had to decide on a path for the build. One case came to me from the west coast and was a worked-over case and had once been a race engine. This case may have been line-honed at some point. IDK... but I am not going to have to do anything funny with it, like shuffling bearings. It only needs boring while the other, which started life as a 2011 factory SB, could not be used the way it was! It came out of my car after about 65 race hours and looked like it could get by with a hone and new coated pistons. What surprised me was how bad the mains were out! I tried shuffling bearings to no avail. I had read that cases could be warped and mains out of line and that torque plates change readings on cylinders, but I had been skeptical. On a previous build all I had to do was have the crank polished a bit on a few journals to get to the clearances I wanted. On this upcoming 500 CHP build, with this "seasoned case", I will get it line-honed and pinned. All surfaced must be shaved for parallelism and flatness prior to the work on the mains and torque plates will be in place during the honing process.
    I guess the short of it is that, for a race engine, I would never trust the main journals to be OK and just slap in bearings. Nor would I shuffle standard and +.001 bearings. The time and energy to verify that all this is perfect and pairing the right pump, etc. is critical to longevity. The second main feeds two rod bearings and if you blow that clearance, or the the next two mains, then you can expect rod bearing problems under extreme conditions.
    I was contributing to this thread on NASIOC recently and thought of you and others who have had bad luck with their 818 engines. Perhaps this thread and others like it could be enlightening. You could start with my first post and go from there. BTW, Chris Bergeron of KillerB is a pretty sharp guy and is a frequent contributor.
  3. #883
    Well, that answers my question before I even open the case. I have an option on a broken in closed deck racing short block, I think we will go that way for our spare.....
    Yes, our shop is line honing, he too said it's the only safe option for a race block.
  4. #884
    That is a blown diffuser? Wonder what the under tray looks like.
  5. #885
    south-central CT
    See the Facebook link! The undercarriage is gorgeous. Looks like 3/8" Alumilite for the middle area. I would like to know the exact materials and thicknesses. I need to get around to putting one on my STi. I was going to go with 4 or 5mm.
  6. #886
    Bowling Green, KY
    I would agree that Chris from KB is a sharp guy and willing to share his ideas and opinions based on experiences KB has had developing EJ parts.
  7. #887
    Reno, NV
    Yes, looks like a blown over the top diffuser. High energy exhaust flow increases the flow velocity through the diffuser and under the car, increasing downforce.
    F1 cars used them for years, banned in 2012. The scary thing about them is when you lift off the throttle the extra downforce goes away, likely when you need it most.
    Interesting article: http://www.formula1-dictionary.net/diffuser_blown.html
    818R Build date 10/31/15
  8. #888
    Edmonton, Alberta
    It's neat how F1 engineers used some tricky engine mapping to prevent this from happening, keeping exhaust flow up on throttle lift.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  9. #889
    south-central CT
    I think they also mentioned flow through. I think that's what it's called. If you have a racing ECM then you can program it to keep the turbo spooling on lifts/braking and you get those neat big flames and bangs!
  10. #890
    Kirkland, WA
    I did the engine swap over the weekend with a friends help, engine went in fine with the headers on, but life would be so much easier if the diagonal 1" bars in the engine bay were either heim joins to removable (bolt in). I have not started the engine yet as I still have to double check everything again to make sure everything is hooked up correctly. All the hoses and coolers were flushed to make sure no metal was in lines, etc.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  11. #891
    Congrats Tony, fingers crossed.
  12. #892
    Sgt.Gator's Avatar
    Bend, Oregon
    Boy I know that new start on a re-built engine feeling!
    I found that pouring an offering of Sake over the engine helps appease the spirits inhabiting Subarus....
    One for you and one for the spirits.
    Good Luck Tony!
    818R ICSCC SPM
  13. #893
    Good luck!!!
  14. #894
    Harley818's Avatar
    Vancouver BC
    Hope that pool of brown liquid on the floor was not critical......
    I'm not racing my 818, but I have my fingers crossed about the engine.
    Too many on here having trouble..... mainly racing applications.
    Good luck Tony.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
  15. #895
    Sgt.Gator's Avatar
    Bend, Oregon
    Tony I really hope you bring it to Spokane next weekend!
    818R ICSCC SPM
  16. #896
    south-central CT
    Your engine... I did not see sandwich plate or provisions for your external oil cooler. You are going back with it, aren't you?
  17. #897
    Kirkland, WA
    Yes it is there, so sandwich plate to remote oil filter to oil cooler and back, I have left the stock oil cooler/heater on also.
    Tony Nadalin
  18. #898
    Sgt.Gator's Avatar
    Bend, Oregon
    Tony are you bringing the 818R to Spokane this weekend? I'll be there racing Friday and Saturday, skipping the races on Sunday.
    818R ICSCC SPM
  19. #899
    Kirkland, WA
    Unfortunately no, but it will be at the Rose Cup Races in Portland 2 weeks later as I still have a few things to do ...
    Tony Nadalin
  20. #900
    Kirkland, WA
    Car is back running again, off to the tuner next week
    http://vid521.photobucket.com/albums...e/IMG_1981.mp4
    Tony Nadalin
  21. #901
    818r center seat biknman's Avatar
    Charm City
    Pic link not working
    FFR 818r Instagram biknman69
    2020 Ram 2500HD, 19 Forester Touring DD, 96 GM coupe for SCCA SM
    “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
    • Ernest Hemingway
  22. #902
    works fine for me
  23. #903
    Sgt.Gator's Avatar
    Bend, Oregon
    I'm registered for the Rose Cup in RC2 with my STI. Hope you'll make it!
    818R ICSCC SPM
  24. #904
    Kirkland, WA
    We are signed up in RC2 I believe also as Tom Ryon put in the entry for the 818R, we will run 1/2 day test and tune on Thursday to see if it will make the race.
    Tony Nadalin
  25. #905
    Kirkland, WA
    Car back from tuners with a very conservative rich tune ... Heading down to the track for test and tune tomorrow
    C430CC09-8E85-4F6E-98A7-264E52AC7D9D.jpg 298055F7-042F-4DEA-93FC-287875E2B7F3.jpg
    Tony Nadalin
  26. #906
    Reno, NV
    Good luck Tony.
  27. #907
    Nice Tony. That's almost exactly the same numbers I make. Have a great time and please post some pics and video!
  28. #908
    Good Luck!!! Great numbers!
  29. #909
    Kirkland, WA
    We broke the front splitter mount today, too much down force, we are also getting an issue of the rear stepping out when shifting, not sure what this is yet
    Tony Nadalin
  30. #910
    Sorry to hear about the splitter Tony. Where did it break? I supported the entire rear span of my splitter with an aluminum angle bracket. I can post pics if it would help give you some ideas.
    RE the rear stepping out, is it when you are lifting or when you are applying power? Remind me again if you have an LSD in your trans?
  31. #911
    Kirkland, WA
    So the rear had toe out, gave it a 1/8 toe in an it's a different car. The oil tem is 210, water temp 185, all seems to be good now, had qualifying today and race tomorrow and Sunday
    Tony Nadalin
  32. #912
    Awesome! I am running a lot more toe-in in the rear than that, and I think Wayne is too, so you might experiment with it. Are you confident you have no bump-out in the rear? That will really cause instability and sketchy handling.
    Those temps are very nice!! Good luck this weekend. Video and pics!!!!
  33. #913
    Kirkland, WA
    Bad day, got flagged for no active transponder and came into hot pits and just as Tom (Tom Ryon was driving as I had my other car there) coming in, brakes failed so good thing Tom went out w/o a transponder on. Fixed brakes and then had a electrical fire on board, so I need to talk to iWire and see what is happening . So car I dead for this weekend
    Tony Nadalin
  34. #914
    Bad day, got flagged for no active transponder and came into hot pits and just as I was coming in, brakes failed so good thing I went out w/o a transponder on. Fixed brakes and then had a electrical fire on board, so I need to talk to iWire and see what is happening . So car I dead for this weekend
    Tony, sorry to hear about your bad day.
    Actually a good day, brakes and fire could have ended a lot worse.
    Tell us some more details so others won't have the same thing happen.
  35. #915
    Ouch sorry Tony. What caused the brake failure? Hope the fire damage was very minor.
  36. #916
    Sgt.Gator's Avatar
    Bend, Oregon
    I had my STI in the same race. The 818R and my STI were running almost identical lap times and we were looking forward to 3 great races (two on Saturday and the Feature Rose Cup Race on Sunday). It was just not to be. Tony mentioned his brake failure which ya'll are right, thank the Lord it happened as his car was coasting into the hot pits to install the transponder. 1 minute sooner and it could have been tragic. Then I did something to my engine which has yet to be determined what actually failed, but it involved enough smoke to put a WWII destroyer trying to screen the US fleet to shame.
    Then I'm sitting in the stands watching "our" race when the 818R came in with what looked like a radiator leak or blown coolant hose, but was actually having an electrical fire!
    All in all a bad day for the only two Subaru powered cars out of 145 entrants. I took a little solace in knowing I had the only 4 door car and the one of three 4 cylinder cars in the actual Rose Cup race. By Saturday afternoon there was only one 4 cyl car left to race on Sunday.
    818R ICSCC SPM
  37. #917
    Ouch, sorry to hear you had issues too
  38. #918
    Kirkland, WA
    So a recap
    1. We were running a 265hp tune on engine, temps were 210-215 oil and 180-190 water temps so all good there, I will have to download data to get IAT and other values.
    2. Had issues with stability, we had to adjust rear toe to get the car from jumping around under shifting/braking
    3. Front splitter had to have center support to keep it from being sucked to ground
    4. So the brake issue was that the brake clevis backed out of the U shaped bracket and thus fell out, this could have been very serious.
    5. Electrical issue, this was a wire harness issue, seems the hot wire from alternator to ing switch/kill switch and hot wire to second kill switch were all burned. Before I say more I need to talk to iWire and find out some more things, this could have also been much worse
    Tony Nadalin
  39. #919
    WOW, you are a lucky guy! both issues could have been much worse, hope you had at least some time on track to sort through things. keep us informed.
  40. #920
    Kirkland, WA
    yes we got enough time in to say the car with the 265 hp tune will be in low 1:20s at PIR, we have to play with tire pressure as we are running 28 in rear and 26 in front and may take those up a pound or 2 as we were getting front end hop in turn 4/5 and Tom made the mistake of taking pressure out because of track was slippery,
    we were running a max of 16psi on the boost and rev limiter is set to 8K
    Tony Nadalin
