Has anyone installed the full fenders and running boards? How do the front fenders attach and are there any braces to keep them from flapping?
I am yet to fit my full fenders. but have given it some thought, the front will attach mainly to the engine side panels, the running boards will need vertical screw into the body section as will the rears. I plan on using nuts and bolts with large radius washers on both sides to add some strength. I also plan to make some additional bracing to run perpendicular to the chassis, especially upfront to prevent them flapping as you mentioned from wind pressure at higher than average speeds ! As with a lot of my build, its still in the pipeline but hope this helps.
Thank you that helps a lot. My headlights are already mounted in the stock position will they clear the fenders?
