cover the fiberglassPicked up an aftermarket transmission mount. It should reduce engine rocking with the added benefit of being 1/4" thinner so it will level out the engine a bit more. It's really heavy, not something you would want to add if your looking to reduce weight.
Here is a question for someone ahead of me, do these triangular front door cavity block off pieces go with the lip covering the fiberglass or on the inside of the fiberglass. They fit better on the inside but I think it would look better with the fiberglass edge hidden.
Dan
