Page 3 of 3 FirstFirst 123
Results 81 to 105 of 105
Thread: Quiny's 818s build
    Senior Member Quiny's Avatar
    Massachusetts
    My build has slowed a bit since starting the nose and fenders. It has been a little frustrating so I have been switching between the car and other household projects. I did need to add an aluminum angle extension on the nose to allow the fiberglass to mount to something. I also had to trim the hood and fenders a lot where they meet the windshield cowl. I still have some fine tuning to do but it's good enough to start on the doors. I found that my Dremel using the drum sander was the most useful tool for the trimming. It's funny I very rarely used them but I have a bunch of them that I have acquired over the years. They last a long time and remove a lot of fiberglass so be careful. A belt sander did a nice job of trimming the edges to make the hood sit flush to the fenders. For those of you struggling with the nose my recommendation is go slow and remember its easier to remove material than put it back. I also noticed that how the windshield cowl is mounted makes a big difference in how the fenders and hood get trimmed. I set the windscreen according to the manual update and found that I almost needed more finished black area on the cowl, I was right at the very bottom. See pics below.
    Freeport, ME
    You will need to trim a bunch off the return on the back edge of those fenders for your doors to open... I'm not sure why they leave so much, it needs to be almost all removed esp at the bottom
    Dan
    Encinitas, CA
    Quote Originally Posted by Quiny View Post
    Agreed... good tip (that's what I've used a lot). However, it can end up a bit wavy, since it's such a small diameter it's hard to make a clean straight edge. I clean it up afterwards with hand files.
    Senior Member AZPete's Avatar
    Nomination for Quote of the Month:
    Quiny: "I'm not sure how my wife will respond to stealing the shower curtain rod for a hood prop, maybe she won't notice."
    (From Everson's engine cover thread)
    Massachusetts
    Started a new job so progress has been slow. I have fitted all the body panels, very slow going. I ended up with pretty good gaps and I installed the front wheel well aluminum. I was able to get the little triangular piece that is supposed to fit behind the door near the top. It took a lot of trimming. It needs to be fitted with the side sails on and the door striker and bracket removed.
    Massachusetts
    Progress is still slow, been traveling a lot. I do manage to get a few hours here and there. I have stripped the body off to make some fiberglass repairs. I'm hoping santa brings me the new style nose. I also did not like that parking switch on top of the steering column so I removed it and patched the hole.IMG_0041.JPGIMG_0058.JPG
  7. #87
    Massachusetts
    Well its been 2 years and yes is still isn't done, but it's not a race. I have been so busy at work and life that the car needed to take the back seat. I have had a little time here and there so I did get the interior done. I have started to reinstall the body but I made everything removable with screws. It would have gone a lot faster to just rivet everything in place. Things went really fast when it was a father son project but both my boys are working on there future at school now. I am working on the rear wheal well sheet metal, I have not seen a lot about it. Any advice? Do the sheet metal tabs go inside or outside the body? It seems like if I make everything fit well the there will be very little room for wheel travel. Any completed pictures or advice would be appreciated.fender.JPGinterior.JPG
  8. #88
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Wow there's a name I haven't seen in a while. Welcome back. Glad you are sticking with it.
    I found it easiest to mount the splash guards with the tabs on the outside. The splash guards are a pain to fit and I had to extend mine to get them to work. I think I have pics in my build thread. I also had to mount them up higher than shown in the build manual to allow for tire and wheel clearance.
  9. #89
    Revived from the dead! Glad you are. I like your S/W btw.
    There isn't much room for the wheel to travel. especially if you have 265s and not modified anything around.
    Unlike Jeff, I fitted mine with the tabs on the INSIDE of the bumper, like on your pic. But I needed to extend that tab a little bit otherwise the metal was stretching too much and it was causing a huge gap, just like on your pic! So I extend it in a way there would be no stretching on the alu.
    I have pix on my build thread, but finding them is another story...
  10. #90
    Mar 2014
    Hingham, MA
    Good to see your name again. You've been on my mind and I've meant to get in touch. We never expected to have completed our build before you. I don't know what the right approach is, but we mounted our rear splash guards inside the bumper with rivnuts. We let the splash guard follow the contour of the inner fender liner which means there is a gap between the inner part of the splash guard lip and bumper, but that seems preferable to where the gap is on yours. We used the Zero dB mounting tabs which worked very well. No issues with tires rubbing, but did have to do some trimming of the inner liners to clear suspension. Sorry, no pics handy. You'll have to stop by and take a look.
    Ivan
  11. #91
    Massachusetts
    Hey Ivan great to hear from you. I will need to stop by and see your build. I have been so busy at work that I allowed my kit to build some dust for some time. Things are starting to get back to normal so I have some time now.
  12. #92
    Massachusetts
    A few updates, I almost have the rear fiberglass completely fitted. It takes great patience but if you fit it, then adjust, and adjust, and adjust, and adjust, eventually it comes together. They key is make nothing permanent until everything is set. You definitely need to handle the nose all by itself after the doors back. I made some changes to some of the sheet metal. It did start and run great after sitting so long. Took the dash out to make fitting all the fiberglass easier.
  13. #93
    Massachusetts
    Well still working on the body install. Mounted the whole body at least 3 to 4 times and still not happy with it. New and old style nose (116 serial#). I'm now forcing the engine cover and trunk to fit with scraps of aluminum angle iron I have hanging around. I do not like forcing the engine cover and trunk to fit but my thought is that I force them in place and then glass the back of them that they will hold position. It may be that my pieces have been hanging around so long that that they bent and twisted themselves the wrong way, or they were not close from the start, who knows. I also had a thought about the airflow problem with the inter-cooler (see the last few pics). I did not expect the body to be so much trouble. let me know what you think about my inter-cooler solution. If forcing these pieces is the wrong thing to do please let me know. At this point I think it will still be a couple of years before I'm done, providing I get the time from work. I still enjoy working on the car when I can.
  14. #94
    Massachusetts
    USA
    I think the scoop would detract from all the work you're putting in to get the panel fitment right. The air to water intercooler setup is really effective and not too expensive.
  16. #96
    Ha! I'm not the only one who needed to trim A LOT the rear humps to fit around the rollbar... hard for me to understand why some, like you and me, do it that much and others no at all.
  17. #97
    Massachusetts
    Blew off the dust, moved the car to my new garage and will start again. Good news is it started right up after 2 years of sitting. Has anyone done anything with this big gap underneath? It looks like the battery tray will fill up with road debris.undercar.jpg
  18. #98
    Welcome back!
    Congrats on the miraculously split of a second engine start after 2 years!
    'bout that space, yes FFR has an aluminum piece to fill that up. Should have come with your kit, I believe, what number are you?
  19. #99
    Norton, MA USA earth
    Quiny? Did you move? Just had a Daytona painted by a guy in your neighborhood.
  20. #100
    Leesburg, VA
    I bent up some left over sheet metal to cover that gap.
  21. #101
    Mar 2014
    Hingham, MA
    Great to hear from you again. I've meant to get in touch to motivate you to finish your car and would be glad to help. I have planned to fill that gap as STiPWRD did. You've motivated me to get it done. You are correct, the gap lets lots of debris into the battery tray and it's a tough area to clean.
    Ivan
  22. #102
    Mar 2014
    Hingham, MA
  23. #103
    Massachusetts
    Thanks for the warm welcome back everyone. Hey Ivan that's exactly what I will do this weekend.
  24. #104
    Massachusetts
    Hey Mike, no I didn't move but I built a new garage with a lift (too old and fat to be on my back anymore). I did see that car and I stopped and spoke with him. Great guy.
  25. #105
    Mar 2014
    Hingham, MA
    I forgot how much I enjoy lying on my back and drilling holes. I envy your lift.
