A decent amount of progress today, but only because I chose not to fix my incorrect front suspension.
Here is a pick of the assembled rear axle using the stock outer, the FF provided middle section, and the inner joints to mate up to the new diff.
For the rear suspension I didn't heat up one of the shock collars enough and spent way too much time beating it into submission. The second one was well heated and dropped in with no effort. When assembling the rear arms make sure you keep the two bags of spacers separated or plan on measuring them to figure out which ones to use. I must say installing those spacers can be a pit of a pain so having a few pry bars or big screw drivers and a mallet helps.
I also realized I didn't have the transmission mount and had to go hunt that down. If I don't have a baby tonight I will be at it again tomorrow.
