I need to run trans oil cooling lines. I can't find or remember seeing if any fittings for the rad were sent or not. That's one. Next is what type of line is recommended. Steel or can I use rubber or braided lines. Finally fitting sizes.
Help
Help
Factory Five Forums - hdnik
FFCars - lowntubd
Build Site/Blog - www.nicks33hotrod.com
There are no fittings in the kit, I believe they are 3/8" npt. Yes, you can use braided lines (I am with my SBC and 700R) and you can use rubber IF they are high pressure lines, like fuel injection. If you are using rubber lines, a trick from my drag racing days was to use 2 hose clamps clocked opposite to ensure you don't blow one off during hard acceleration.
FFR HR #530
For my Ford AOD I bought JEG's stainless trans cooling line kit (Specified for a 350 TH) and the individual -6 AN fittings. Problem is the advice from several folks have me with the wrong AOD fitting size. It's a METRIC Trans. Advice was 1/4"NPT. Wrong. Anyone know what's correct?
This page shows them as 1/4 NPT...
http://www.tciauto.com/tc/cooler-fittings
FFR HR #530
1/4" npt here. Not sure why yours would be different.
FFCars - lowntubd
Went out to the garage and looked at mine, 1/4" NPT
