Likes Likes:  2
Page 2 of 27 FirstFirst 123412 ... LastLast
Results 41 to 80 of 1079
Thread: MRG MotorSports 818S Build
    Senior Member Brando's Avatar
    Irvine, Ca
    Quote Originally Posted by JeromeS13 View Post
    No problem. I love the OpposedForces website for things like that.
    That saved me so much legwork looking for a few random missing parts. Thanks!
    I'm Doing my wiring dissection.
    I am going to keep the OBDII connector in this diagram.
    Do I need the rest and what are they for?
    You'll need B75/B76 if you want to flash the ECU. You might also need B300, depends on the year.
    Quote Originally Posted by Ravendas View Post
    It was an 04 forester XT
    Wire Disection
    I am doing a wire dissection not a wire diet.
    Instead of pulling out all the all the unneeded wires, I am removing all the needed wires.
    This is something I can do without going out in the cold garage.
    A couple of pictures.
    Wire disection Continued
    I pulled out each of the sub harnesses that I need.
    Wayne's Harness is looking better every day.
    Ok, then you just need the test connectors. No jumper block is necessary.
    Transmission installed
    I thought I'd put up a couple of pictures of the 818 ICE
    Senior Member AZPete's Avatar
    Please stop posting pictures of your blue frame. It makes me jealous and regretful. :-)
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    I admire that you're doing the wiring. Stay the course.
    The site of your green table makes my forearms phantom itch. Dah!
    ok, here is a picture of my 818 BEV
    Thanks. I'm feeling better now and capped the vodka.
    Exeter R.I
    Hey your missing a body lol
    Jan 2012
    Surry Va
    Who made the seat your using?
    Quote Originally Posted by gwarden View Post
    That was just a temporary seat from Jegs $40
    Note: That seat is only 1" from the floor and my daughter in the picture is only 5'4"
    Location Of battery discnnect switch
    What is the most desirable physical location for a battery disconnect switch to meet racing rules?
    In the circuit it obvious that the switch goes between the battery plus and the fuse block.
    Does the main starter cable got through the switch or not?
    Does the alternator main wire attach before or after the switch?
    Thanks Bob
    "It shall be mounted so that it is easily accessible from the outside"
    Either outside the car or right inside the body to the left of the steering wheel would be the best spot.
    You want to eliminate all live circuits in the car, so severing the connection as close to the battery is what you are trying to accomplish.
    to do it right, a kill switch with alternator protection is probably your best bet.
    It will short out the alternator and eliminate the chance of the car continuing to run
    https://www.pegasusautoracing.com/pr...asp?RecID=1464
    "It shall be mounted so that it is easily accessible from the outside" Either outside the car or right inside the body to the left of the steering wheel would be the best spot. You want to eliminate all live circuits in the car, so severing the connection as close to the battery is what you are trying to accomplish. to do it right, a kill switch with alternator protection is probably your best bet. It will short out the alternator and eliminate the chance of the car continuing to run
    Thanks LongIsland,
    I'm glad I don't have to run the #2 starter wire through the switch.
    I see they use and auxiliary contact to the ignition coils. This is because things like radiator fans, alternator and blower motors act as generators to hold up the 12 volts for a few seconds after power is disconnected.
    I need to buy some aluminum for the rear firewall. Where do I buy a 24" x 48" sheet from?
    Motor side of wall. Has somebody made a sketch for this piece?
    Freeport, ME
    I buy full 4 x 8 sheets from my local steel and other metal supplier. Check online When I ran a search 5-6 popped up in the Cincy area. They may sell sheared, partial sheets and will def. shear to any size you want for a fee
    Dan
    Encinitas, CA
    If you don't have a local place, this week, I bought some steel and Al from:
    onlinemetals.com
    Great selection and they'll cut to spec. Really fast for the first shipment, still waiting on a couple pieces. They even provide cert sheets.
    It much easier before you drop the engine in! I bought a piece of .040 aluminum big enough for the rear firewall (17" x 50") but then could not get it in place with the enginein, so I cut it into 3 pieces. Now, I can easily remove & install any of the three with the engine in place. I'll post a photo when I get home that shows 2 panels removed as I work on wiring.
    Edit: See new Rear Firewall thread in Body section.
    Last edited by AZPete; 03-03-2014 at 06:20 PM. Reason: we're hijacking so referred to new thread
    Freeport, ME
    Pete, my engine's been in for months... I want to do pieces, photos please... I'd love outlines...
    Dan
    I'm Working on a cad drawing. I still have to measure a couple more time before I trust it's accuracy.
    Hey guys, we've highjacked the MRG build thread! I just added a new thread in the Body section about the rear firewall.
    Okay, MRG, continue on.
    Shorten transmission
    As the transmission is so exposed to the rear of the car. I decide to find a way to make it shorter.
    This is my solution.
    The plain white box is a hole cut in the side of the transmission. The red box is a bar attached to the front of the shifter shaft.
    A bellows would be added to keep oil from splashing out the hole.
    I am going to cut everything off at the neutral safety switch. I could go a couple of inches shorter but I have to leave enough for the shifter shaft slide bearing.
    The rear of the transmission will be sealed by welding plates over exposed holes.
    The green bar sticking out the side can be connected to cables or a linkage to the shifter.
    Let me know if I was clear on this modification or if you have questions.
    Leesburg, VA
    Wow that seems like a complex modification. I'm curious to see how it will look when finished. How are you planning on sealing the bellows to the transfer case housing and attaching the bar to the shift selector shaft? I hope none of the bearings supporting the lower pinion shaft and selector shaft will be impacted by cutting the transfer case at the neutral safety switch.
    No bearings will be affected. See this picture. all the bearing in in that section are for the center dif.
    This picture also is a good shot of where the locking collar goes.
    Sealing the bellows to the case is not totally worked out yet. I'm looking at something like this:
    I will have the bar welded to the shift selector.
    Up would be 5th and reverse
    down would be 1st & 2nd
    forward would be 1st,3rd,5th
    backward would be 2nd,4th, rev.
    Freeport, ME
    It will work but seems to be too complicated... there is tons of empty space in the transaxle case.
    why not just shorten the shaft and modify the shifter brackets, that should leave a couple inches
    the rear of the bumper should have been a couple inches longer, leaving room for a proper bumper behind the fiberglass
    Dan
    I was looking at this from a racer point of view. With my set up the car can get bumped in the back and the shifter mechanism will survive. Also have 6-7" between the trans and the fiberglass leaving plenty of room for some nerf bars.
    This might be an option, too.
    http://www.subarugears.com/FAQ/FAQ.html
    if you read through their guide, you will need a certain center housing and one of "their plugs", or the right size freeze plug.
    Quote Originally Posted by icky View Post
    Great find ICKY
    The below pictures show the locking collar installed. The second picture shows the transmission shortened to the max.
    You have me debating on where to connect to the shifter shaft.
    As you can see in the second picture almost 6" (eyeball measurement) could be cut off.
    Member Slatt's Avatar
    Anchorage, AK
    Creating room at the back would help so many of us for so many different reasons. I enthusiastically say follow your muse on this one. And let us know what the machine costs look like.
    Does any one have an extra center diff housing laying around for me to practice on?
    Or can I buy them somewhere?
    Taking a brake from 818
    No, this has nothing to do with my BRAKES,
    As the temps got up into the high forties today. Mike wanted to go play in the mud.
    See before after pictures below.
    after
    It was a very sticky mud and clay mess.
    took it to the carwash, it was frozen
    Spent about an hour with hose and pressure washer cleaning it up.
    Exeter R.I
    Go on Nasioc, you will find one
    Mechie3's Avatar
    Great find ICKY
    Where did that piece come from? I have a transmission case with broken gears that i intended to get rebuilt but would be interested in try to replicate what you see in that photo and sharing what i find.
    Edit: found the video you got those shots from.
    Zero Decibel Motorsports
    for those that are internet handicapped. After watching again, you can just tig all the holes with 1/8" aluminium plate.
    Hi Mechie3
    That will definitely shorten thing by 4 or 5 inches.
    I'm going to leave the case the same length as the outer tube shown in the picture. That way if you get bumped, nothing gets hurt internal.
    I will attach my shifting mechanism to the other end of the shaft.
    Busy right now with my wire dissection.
    Mechie3's Avatar
    I like the super cut down version with the custom sleeve. They could probably cut the shaft a bit too.
