Hi StiWRD,
My goal is to get the cables down in the tunnel.
I was looking at mounting a base plate on top the tunnel, then flip the bell crank so it points down.
Then extend the shift arm down and connect cable outer jacket.
In theory all would work, to implement it would be hooky.
I think you and I are going to end up with the same thing. Last night I decided it wound be much simpler to just drop the shifter 2" into the tunnel to the tunnel, which would hide the cable and be pretty simple to implement.
I should have this done by Wednesday, I will post pictures.
