0
Originally Posted by
RM1SepEx
Harley, I'm between 5/8 and 7/8 on the side sails, my rear lower brace allows for no additional forward movement on the rear clip! I can't go farther back or the side brackets for the door latch can't meet the body opening. I only have 13 inches to the sides of the rear wheel openings from the shock mount. My back/side fender mounts are tweaked to make them follow the body contour better and shimmed up with a couple washers. My only problem now is the roll bar clearance
Dan
one way I am considering gaining roll bar clearance is to move the engine covers back and add material to the door interface area of the panel with humps.
