Page 2 of 2 FirstFirst 12
Results 41 to 71 of 71
Thread: Wheel Studs, Lug nuts, and 1.25 fine threads
    south-central CT
    Bob in Cincy: see my post#24. Not uncommon. Get Arps!
    Thanks Scargo
    I understand cross threading during installation. I run the on with my fingers. They are not getting cross threaded.
    I fully intend to us arp 1.5 on my 2 818.
    Looks Like I need a third set.
    What lug nuts do you recommend
    .Bob
    south-central CT
    No insinuation intended that you don't know what you are doing. The stock stuff just can't take the repetitive use and constant re-torquing and stress of the track.
    Go wild or mild on lug nuts. I use inexpensive, heavy-duty ones from Summit. Lots of threads. 65 cents ea. Good quality/no issues.
    $13/set? NOTE: these won't fit all wheels. They work on my 949s and my Enkei PF01s.
    Go wild with titanium@ $26 ea:
    t1r_lugnuts.jpg Hmmm, where could I spend $506 more wisely?
    Hey Scargo,
    No insinuation taken. It was late and I was tired if I sounded like that.
    I just measured the clearance hole on my OEM wheels at 1.2". A standard socket is no issue with the 13/16 nuts. I will check a impact thick wall socket later.
    I'll pass on the titanium
    Aug 2012
    Long Island
    You can get a nice set of titanium nuts for $300 or less, pricey yes. but not $26 each pricey.
    I just bought 2 cars worth of EVO ARP-100-7717 3" m12x1.50 studs.
    Edit: I went with the 1" thick summit SUM-7540021 nuts. (thanks Scargo) Not so pretty but look strong.
    If you don't want them to stick out so far. It looks like you can go to the shorter ARP-100-7718 Toyota studs at 2.34 long. The knurl length is 0.325 as opposed to the Subaru 0.270. The hub is .393 thick so I think no issue. This would prevent you from adding spacer.
    south-central CT
    You go first... Are they sturdy enough for racing or just a pretty, lightweight tuner lug nut?
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    If you don't want them to stick out so far. It looks like you can got to the shorter ARP-100-7718 Toyota studs at 2.34 long. The knurl length is 0.325 as opposed to the Subaru 0.270. The hub is .393 thick so I think no issue.
    Confirmed. Good catch BnC. Hub's 10 mm thick. Rear shown.
    And there's plenty more room in there for longer knurls. ARP-100-7717 shown in picture. If the ARP-100-7718 Toyota knurls are only 8.3 mm long they'll easily fit inside the Subaru hubs.
    Aug 2012
    Long Island
    HA HA no thank you... but who knows down the road.
    legit nuts. they come rounded to finger spin or full depth splined (which I like)
    20 12x1.5s with driver for $245
    I'll stick with the EVO studs... sticker shock when I saw the Toyota price.
    Hi Guys, I can safely assume the stud length will need to be adjusted according to the wheel thickness and if a spacer is being used.
    That said, if the wheel is spaced out, and the offset of the rim pushes the wheel outwards. How far is the maximum before the bearings are being loaded further out away from the center line of the bearing, rather then just the weight of the car pushing straight down on the center of the bearings?
    In the old days when we put wider rims on the front of cars and trucks the outer wheel bearing was now the load carrying bearing and failed after very short duration.
    I understand the car is substantially lighter than the original WRX. But I don't want to trash the new bearings being a few hundred bucks with seals!!
    For an example, Lets say there was a three foot spacer behind the wheel, now the load on the bearings are a twisting load rather than a linear load directly on the rollers of the bearing. How strong do the bearings need to be to hold that extended moment??
    Las Vegas, USA
    Subaru's front bearing set is the same race and rollers inside and outside. I'm trying to set up mine like a race car so I'm more worried about scrub radius for my front wheel offsets than looks. I'm looking to get the scrub radius as close to zero as possible but not go negative.
    south-central CT
    Any thoughts as to what that ideal offset would be? I don't like the idea of running spacers. Does it require compromising the tire size or diameter?
    Do you know any real world numbers of what RWD cars run and what's considered acceptable if you don't get to 0?
    Neat link, BTW. I was fascinated by the idea that you could groove the backing plate of a disc brake pad for improved cooling. Googling that concept came up with "0".
    Las Vegas, USA
    I don't. Jim Schenck might know. I just don't have a chassis in front of me to measure where the imaginary line that runs through the two pivot points on the front suspension intersects the ground. Though there would be a few minor effects from variation in spring perch height and where you set your camber and caster. The biggest would be the diameter of the tires you choose to run, because that effects where "the ground" is.
    south-central CT
    I do have this for the blue R car:
    Front:
    Motion ratio is .795
    Shock angle correction: .906
    Roll center: 2.8 inches (with 215/45/17 tires at 4.5 inch ride height)
    Rear:
    Motion Ratio: .877
    Shock angle correction: .985
    Roll center: 4.0 inches (with 255/35/18 tires at 4.5 inch ride height)
    I don't know if the roll centers are the simplified "
    Force Based Roll Center" or not (as from the link you recently posted from Racecartuner.com).
    Jim S. sent them to me.
    Exeter R.I
    I would say 35-30mm offset front with an 8 inch wide wheel. For the back a 42-32mm max offset with a 9 inch rear wheel, 9.5 if you wanna push it
    Aug 2012
    Long Island
    has anyone used a percys wheelrite?
    they look very cool and would help me try out various fitments
    http://www.speedwaymotors.com/Percys...Fafm7AodSyUAlA
    Hi Guys heres a picture to help understand the offset/back spacing and such.
    south-central CT
    Long Island TEA... I mean "WRX", That's a neat toy. ('spensive)
    I just use cardboard and the many calculators on the internet. My favorite: http://www.rimsntires.com/specspro.jsp
    Another: http://www.1010tires.com/Tools/Wheel-Offset-Calculator
    I've got more
    Aug 2012
    Long Island
    yeah I've just used cardboard in the past, but watch some of the youtube videos on that bad boy, pretty powerful.
    I found it for much cheaper too.
    This is what the look like in stock OEM wheels:
    Edmonton, Alberta
    Is that spaced for the rotor?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    I left them hanging out the bottom about 1/2" for rotor and hub.
    Sep 2011
    Wareham + Bow
    We are also now producing these for those that have not already purchased ARP.
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    I have the fine pitch ARPs and the first time I put the wheel on, just barely brushing the threads of the stud with the wheel, the threads were smashed enough to make the lug very difficult to go on... I actually skipped that stud and will run a die over it before putting a nut back on. Very annoying. Good suggestion of going with a coarser thread.
    Senior Member Mulry's Avatar
    Dallas
    In a slight zombiefying of this thread, I thought I'd add our experience with spacers. We've run spacers on both of our non-FFR racecars for years without any discernable negative effect. A lot of internet racing experts will say that it adds stress on the lugs or elsewhere, and that's probably true. But in 5+ years of endurance racing we've never suffered a failure at the wheel, hub, or tire that we would attribute to having run a spacer. We've run up to a 20mm spacer on the rear of the MR2 and a 20(?) on the front of the e36. We have had wheel failures, but those were exclusively due to getting hit by other cars on track. I love the weight and profile of the Enkei RPF01 wheel, but it does not handle contact very well. YMMV, etc. Cheers.
    south-central CT
    As you say, "YMMV". I don't have the extensive racing experience of some. Some cars have much better wheel bearing designs and some are overbuilt. It is a fact that more stress is exerted on the wheel bearings the farther you space out a wheel, if all other things are equal. How much is something I cannot define. I know many run spacers. In fact I just got some dinky ones for my Subie because the springs were rubbing against the tires.
    Senior Member Buzz Skyline's Avatar
    May 2013
    Greenbelt, MD
    Why is the knurling missing on the second one from the right?
    Quote Originally Posted by AJW Performance View Post
    Quote Originally Posted by Buzz Skyline View Post
    They where looking for a new quality control employee.
    Congratulations, you get the job
    Jun 2015
    We use only the ARP Mitsu Evo m12x1.5 on all of our cars, along with titanium lug nuts with a 17mm drive. Perfect length, can't cross thread and since all the cars are the same, we have tones of spare nuts for enduro (at $130 per set .....)IMG_0341.JPGIMG_0342.JPG
    Yes, I know... bump steer spacers....getting there!
    Senior Member HCP 65 COUPE's Avatar
    NORTH CENTRAL CT
    Coming from a machining background and knowing how ARP is producing m12 wheel studs by thread rolling the blanks the Mitsu and Subi studs are probably
    produced on the same blanking equipment and then separated into different part #s after thread rolling, meaning they have the same part# before the
    thread is rolled. At least that is how I would try to produce those parts, cover 2 applications or many more with as little equipment and tooling overhead
    as possible and maximize lot sizes and minimize setups.
    Kirkland, WA
    Quote Originally Posted by RetroRacing View Post
    What length nuts do you use ? I will be using these http://www.amazon.com/gp/product/B00..._detailpages00
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
