We've been pretty busy since the last post. We have most of the brake and clutch lines run, installed the gas pedal and started the wiring harness on a diet. We've been relying pretty heavily on data provided by mechie3 and rm1SepEx - thank to both of you for the information in your threads and PMs. We're getting stalled by missing parts. We found that if we installed the gas pedal as is indicated in the manual, it doesn't have nearly enough pedal throw nor is the pedal in a comfortable position, so we adapted and installed the pedal directly on the firewall using the plate provided as backing support. I'm including a photos of the finished pedal and a before and during shot of the harness work - which takes more time to de-bundle than it does diet the harness.
