It's been a while since I posted in my own build thread, so I guess I'm overdue for an update. FTW (the local tuning shop working on my engine), finished with my engine, so I wanted to get that installed in the frame. Mostly because I didn't really have another place to store it! To make a long story short, logistics were an issue and the best solution was to get to the roller stage, so spent what little time I had doing that. I will have to go back and take of some things I skipped (like the alum panels).
Here's a pic of the engine going in (a lot of stuff is not attached), and another of the engine sitting in the frame:
I think the engine came out looking very good. I'm very pleased with the results and time & care FTW put into it! Details of the engine work are in my next post, but the high level summary is that I extended the rev limit to 8000 (stock is 7000), did work/mods to help the engine rev more quickly and flow better, and enhance reliability. My emphasis wasn't on outright power, but rather focused on increasing both performance and reliability. For instance, an engine that revs more quickly will accelerate more quickly. Extending the rev limit does several things:
- An extra 1000 RPM means more time in gear. More time in gear means less time shifting.
- Shifting at 8000 RPM (as opposed to 7000), puts you higher in the RPM range in the next gear than you would have been otherwise. This means more boost and more HP available.
- Greater RPM range makes all the gears more useful by providing a greater range of use and more flexibility in regards to gear selection.
This all translates to faster 0-60 & 1/4 mile times (or lap times, if that's your thing).
I'm also in the middle of a conundrum, which I will post separately from my build thread. I would appreciate the perspectives of those knowledgeable.
I have more videos, but I'm a bit behind on posting them. Hopefully soon!
Tool Review: Channellock Snap Ring Pliers
Verdict: Awesome!! They change from push to pull with the flick of a lever, and come with multiple ends. Look no further than these!
