Likes Likes:  4
Page 10 of 11 FirstFirst ... 891011 LastLast
Results 361 to 400 of 411
Thread: SixStarCars' 818R - NASA ST3 - SCCA Solo X Prepared Build Thread
  1. #361
    818r center seat biknman's Avatar
    Charm City
    Howdy from Charm City! Where did y'all get the Alumalite from?
    TNX Dave
    FFR 818r Instagram biknman69
    2020 Ram 2500HD, 19 Forester Touring DD, 96 GM coupe for SCCA SM
    “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
    • Ernest Hemingway
  2. #362
    Feb 2013
    Westminster, MD
    That's good stuff from what I've heard. Will it be stiff enough in 1/4" thickness for a splitter? I saw earlier pic of intercooler in the back. Is it staying there and is it working OK there? What kind of temp drop do you get?
    It's very ridged. Even as the full 4'x8' sheet I couldn't get more than a few MM of deflection.
    The intercooler has been there since day 0, I love it. I think the best thing ever was when we were tuning the car and my buddy asked, "Are you sure this has a Subaru engine in it? Your ECT and IATs are way too low seeing as how we just made a 24 pound pull!"
    We actually had to stop shutting the car off as it was getting too cold between pulls!
  3. #363
    Feb 2013
    Westminster, MD
    Quote Originally Posted by biknman View Post
    TNX Dave
    Any local sign shop should be able to get it. Plan on $100-$120 depending.
  4. #364
    Feb 2013
    Westminster, MD
    Deleted my dipstick after the failure, needed a vent. Got clever with some leftover intake manifold bits. Free.99!
  5. #365
    Edmonton, Alberta
    Quote Originally Posted by SixStar View Post
    What failed? And why do you feel the diff housing needs a vent?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  6. #366
    Mechie3's Avatar
    Indianapolis
    His dipstick broke and dropped into the trans. He deleted the dipstick and plugged the dipstick port with an NPT fitting. The dipstick is a combo dipstick/vent so with that plugged he needed to vent it somewhere. He posted pics on FB.
    Zero Decibel Motorsports
    Check out my new website!
  7. #367
    Senior Member DSR-3's Avatar
    San Jose, CA
    re. the pigtail vent hose; Long ago I tried that on a Hewland Mk9. It filled with oil, which created enough restriction to cause the seals to leak. A different animal, but worth considering. As I recall I just pointed the tube rearward (270deg curl vs 360) so it couldn't fill and was leak free (at least from the gearbox!).
  8. #368
    Feb 2013
    Westminster, MD
    Quote Originally Posted by DSR-3 View Post
    Good to know!
    Was there fluid in that part of the box I'm assuming? There's really nothing going on in the back of our box so I'm hoping it's a non issue.
  9. #369
    Feb 2013
    Westminster, MD
    Quote Originally Posted by mechie3 View Post
    his dipstick broke and dropped into the trans. He deleted the dipstick and plugged the dipstick port with an npt fitting. The dipstick is a combo dipstick/vent so with that plugged he needed to vent it somewhere. He posted pics on fb.
    fact!
  10. #370
    Feb 2013
    Westminster, MD
    Last night was fairly productive - http://imgur.com/a/WaDhj
    First start up this morning, she idles perfect, few more bits to bolt back on then back to the dyno for tuning.
    Also, for anyone wanting to keep their turbo bolted down forever - https://www.full-race.com/store/turb...ware-kit.html/
    Amazing kit.
  11. #371
    Feb 2013
    Westminster, MD
    Put in some dyno time today. Pretty pleased with the results.
  12. #372
    Edmonton, Alberta
    Wow! Nice numbers! Can't wait to see video of it on track. I also have the full-race stud kit for my turbo, no testing yet but I hear good things.
    818 SRX - #91
    Arrived 01/02/2014
  13. #373
    May 2013
    Colombia
    Going back a few days in the thread... The dipstick is definitely the vent for the gearbox. The subarugears guys do a reverse crown and pinion kit for rear engine vehicles (porsche and VWs with subie trannies). When you reverse the crown, you have to block the dipstick otherwise you'll get oil flying all over the place. To replace the vent through the dipstick, they drill a hole closer to the center differential. Check out the following video, from minute 9:00, also the exact location of the new vent is shown in minute 9:40:
    https://www.youtube.com/watch?v=yncdDekf0A8
    Very cool dyno btw. Hopefully it's reliable.
    Speedy G
  14. #374
    Feb 2013
    Westminster, MD
    I confirmed my idea with the SubaruGears guys before I did it. Worked fine yesterday and there was definitely some heat generated.
    As for the power, it will rarely be run at this level. I currently only have it set for "The Beans" at the top of 3rd, 4th, and 5th. BBG on the COBB AP is pretty slick!
    Bonus from the dyno session, proof that the RMIC works as a heat exchanger even with no airflow (car was on the dyno backwards)
  15. #375
    Feb 2013
    Westminster, MD
    DIY splitter DONE! Also good to about 200#, tested.
  16. #376
    Apr 2015
    Andover, MA
    Would you share some of the details of your DIY splitter? I have a 1/2" plywood splitter on my car right now an think with some fiberglass cloth and resin it might be good enough for my non-track (i.e. aesthetic) purposes. Curious how/what you did? If you already covered it, just say and I'll dig back through to find.
    Thanks!
    -Ben
  17. #377
    Feb 2013
    Westminster, MD
    Quote Originally Posted by ben1272 View Post
    Thanks!
    -Ben
    I build better than I document. Short version; 4x8 sheet of Alumalite, used the vestigal FFR splitter as template but extended it to the battery compartment, cut for the 255s, mounted some hangers, had to make a jack point also.
    Here's a bunch of pictures first - http://imgur.com/a/lRLyu
  18. #378
    Apr 2015
    Andover, MA
    It looks good, and is obviously strong, nice job.
  19. #379
    Senior Member EODTech87's Avatar
    Feb 2013
    Copperas Cove, Texas
    What thickness was the Alumalite?
    How does it compare to the FFR splitter when it comes to weight?
  20. #380
    Feb 2013
    Westminster, MD
    Quote Originally Posted by EODTech87 View Post
    I used 1/4" for this. It's heavier for sure, I have not weighed it.
    I can say this, it's proven to be able to hold 191lbs. more than the last one...
  21. #381
    San Jose, Ca.
    Lol !
  22. #382
    Feb 2013
    Did you look into dibond? Any reason why you choose alumalite over it?
  23. #383
    Feb 2013
    Westminster, MD
    It's what my local sign shop had. Aren't they just different brand names for the exact same product?
  24. #384
    Feb 2013
    Westminster, MD
    Some AX fun from this past weekend.
    The car needs tires, bad.
    https://youtu.be/ecEVRAduH0E
  25. #385
    Feb 2013
    The dibond is solid core so they tend to be thinner and also run cheaper.
  26. #386
    Feb 2013
    Westminster, MD
    Interesting. Some quick research shows it being about 5-6lbs heavier in a 3mm thickness and costing about 50% more. It would be pretty slick to do an apples to apples comparison on strength vs. thickness and throw cost into the mix.
  27. #387
    south-central CT
    The laminated aluminum sheets, which are typically used as durable signage are called a number of things.
    Alumilite seems commonly used by racers. Often 2 axis CNC cut to shape. Up to 1/2" thick, I believe.
    http://www.multipaneluk.co.uk/produc...oil-and-sheet/
    http://www.laminatorsinc.com/sites/w...nel-Colors.pdf
    http://www.nudo.com/Sign-Panels/Func...PolyMetal.aspx
    http://www.nudo.com/Sign-Panels/Desi...AlumaCorr.aspx
    http://dragonplate.com/default.asp
    http://www.grimco.com/Products.aspx?cid=0198&pid=00408 MAX-metal and AlumaCorr
  28. #388
    Feb 2013
    Westminster, MD
    I'm thinking of building a CNC router to cut out some different versions for testing and destruction.
  29. #389
    Feb 2013
    Westminster, MD
    New tires! More Grip!!
    https://youtu.be/5dWTh6CllZM
  30. #390
    Feb 2013
    Westminster, MD
  31. #391
    Aug 2012
    Long Island
    looks like great weather, nice run!
  32. #392
    I think my sister was at an Autocross event you were at--the Farm Complex in Harrisburg. I got a picture text with your car in it and told her to creepily check your license plate. Any chance you're entering the one at Pocono this weekend? I could come check out your car (my first in-person 818) under the guise of "supporting my sister"...
  33. #393
    Feb 2013
    Westminster, MD
    Quote Originally Posted by wmaurojr View Post
    I was at the SUSQ AX - https://youtu.be/ecEVRAduH0E
    I won't go that far for an AX, but there is another one this Sunday at the Farm Show again. I might go, need to work on the on power turn in.
  34. #394
    Feb 2013
    Westminster, MD
    Always a work in progress. Saved some space with a new expansion tank too.
    http://imgur.com/a/7EaqN
  35. #395
    Feb 2013
    Westminster, MD
    Hmm, something is brewing around here....
  36. #396
    Feb 2013
    Stop teasing us and spill the beans.
    -Jason
  37. #397
    Feb 2013
    Westminster, MD
    Omelets and eggs
  38. #398
    south-central CT
    Round steak and shelled peas?
  39. #399
    QC, Canada
    Scrambled eggs, looks like.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
  40. #400
    Charm City
    Any updates?
    • Ernest Hemingway
