0
0
Steering Rack Question
I have a 2003 donor. I've got the rack all apart, and already cut the piston seal off the main rod. My question is about where to place the weld to remove the slop. The previous discussions were all about the newer racks - mine looks different. Any help would be appreciated.
I didnt weld my 2002 and have almost no slop. In fact I would say I have none at all.
I have a 2002 and I did weld it. If you remove the pinion assembly from the housing there is a snap-ring that holds the valve body assembly on it(its like a plastic cylinder. Remove the snap ring and the valve body (you can discard it since you wont need it) once the valve body is removed you will see were the 2 shafts come together. Lock one side in the vise and use vise-grips to rotate the other end. You will see the spot then.
- You may not post replies
- You may not edit your posts
Forum Rules
