On the older arms the threaded section where the ball joint screws in was not centered in the plate so the ball joint could screw all the way in but still look different side to side. As long as the ball joint is tightened down as far as it can go this has no affect on the geometry, but if the ball joint looks like there are still threads showing then it needs to be screwed in more until it is fully seated to be safe.
