That is Awesome.
How is boost control handled with this setup?
The ecu is only boost limited by the MAP sensor installed on the motor. If you put a 5 BAR sensor on then 57 psi
Cool
I will add a "super cool". i can't wait to do the wiring with your set up.
Does it use the factory wastegate solenoid?
Added pic in first post
Hmmm. My post disappeared.
So we dont need a stinking key right? Very Cool
Thanks- Chad
Your post disappeared because there are two threads with the same exact name in different categories. You aren't crazy
No keys required for the R harness.
Does this support the JDM engines ?
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
I would like to use a keyless system with my S harness. With some security/ battery switch. I will also use the AIM system you had suggested.
Dru
What was the price for the S version? I like the simplicity of this, but I still would like to do horn/signals/headlights. seems like it wouldn't be hard to add those 3 circuits to this.
The S version is $2150 and runs horn, factory instrument cluster, wipers, hazards, turn signals, back up lights, high beams, low beams. The high beams, low beams, tail lights and horn require a relay each, the turn and hazard require a no load flasher each, then add two wires from front to rear for the turns, another two wires to the front for the marker lights and horn. So adding those "3 circuits" is more involved.
Yes the R harness is set up to run the AIMsports, Racelogic and Racepak dashes. The fan switch is an override as the ECU sets the fan turn on/off temp. The light below the switch comes on whether the ECU or switch turns the fans on.
I could add the switch panel to the S harness for $100 extra.
Wayne-
How much for the Racepak IQ3 dashes (Display only and Display/Datalogger)? Thanks
Thanks- Chad
how much of the factory wiring harness is required for the S version?
I have a set of pics with the cut lines on the harness but it's the engine plug(s), both harnesses on the passenger side of the motor at the grommets, fan plugs, dash sub harness with two plugs, steering column harness, brake/clutch plugs and one of relay blocks.
Tony Nadalin
If the fan is on, the light is on whether you flip the switch or the ECU turns it on.
