Jeff,
Very informative as usual. It's been a long time since I assembled the shocks. That was the first thing I did. Since I had them assembled, I must have taken them apart. I do think I tightened the jam nut as instructed but I did not add lock tight. It's not in the manual but that's no excuse. That's on me.
I contacted FFR just to cover all bases. I was told by Tony that there was no recourse for FFR to help (since no inventory of Bilsteins). That was to be expected. So I got with
Bilstein West and got the ball rolling. I will try the upgraded ones for a while but I think I will probably migrate away from this setup to something more in line with the other folks. I remember looking at the shocks when I first got them and thought to myself, "these just don't look very substantial more like kart shocks than real car shocks". Hope the upgrades change my mind. If not I may be changing over even sooner.
I've always heard it's better to be lucky than good. I think I have had more than my share of good luck during my life: skiing off clifts and hitting a bridge at 60 along with many other close calls so it's time to be good and lucky (starting with this upgrade).
I'm glad the service you mentioned is still available. I must be one of the last change overs. I do appreciated the contact info and history lesson too.
Would you do anything other than adding blue lock tight to the procedure? I thought about putting a couple of reference marks to the jam nut and shock head that I could inspect periodically.
Thanks Gordon. I guess I will be talking with you when the time comes for me to switch over.
JL1958: Do you have an IRS or the live axle? I have not heard of any
Bilstein shock failures on the rear except IRSs.
WEK.
Note: the roadster will be on the lift for a couple of weeks while the Bilsteins take a much needed vacation to sunny CA.
