I'm working on my rear suspension and came across this problem. The rear transverse link (with the sway bar mount) bolt doesn't thread all the way on the frame end. Because this is the one with the offset washers I was thinking it is likely difficult to source a longer one. I'm contemplating filing/machining down a bit off the outside of the funnel shaped metal bushings. Has anyone else run into this issue? If so, what did you do? One pic shows the lack of threading, the other the bushings I mentioned. I couldn't find this in the suspension forum, and gave up digging through the builds. Thanks!
