0
0
Aeroquip AN fittings, and stainless steel hose special from The Race Line
Hey there everyone,
So I know that AN fittings can be quite expensive. They look great and make building lines substantially easier, so I thought I would put some of the more popular fittings out here at a discount and see what the interest is. These fittings are all Aeroquip reusable fitting, designed to be used with their stainless steel braided hose, which I also have listed here at the bottom. Let me know fairly quickly on this first order, as I am going to be placing a order here soon. Also if you do not see what you are looking for here, give me a call. I only listed the most popular fittings here, and there are certainly others available.
Happy Building all.
$6.30 -6AN STRAIGHT HOSE END
$8.73 -8AN STRAIGHT HOSE END
$10.89 -10AN STRAIGHT HOSE END
$22.65 -6AN 30 DEGREE HOSE END
$24.91 -8AN 30 DEGREE HOSE END
$29.79 -10AN 30 DEGREE HOSE END
$16.95 -6AN 45 DEGREE HOSE END
$20.58 -8AN 45 DEGREE HOSE END
$23.50 -10AN 45 DEGREE HOSE END
$22.65 -6AN 60 DEGREE HOSE END
$24.91 -8AN 60 DEGREE HOSE END
$29.79 -10AN 60 DEGREE HOSE END
$31.15 -6AN 90 DEGREE HOSE END
$32.70 -8AN 90 DEGREE HOSE END
$30.34 -10AN 90 DEGREE HOSE END
$31.15 -6AN 120 DEGREE HOSE END
$36.88 -8AN 120 DEGREE HOSE END
$37.32 -10AN 120 DEGREE HOSE END
$31.15 -6AN 150 DEGREE HOSE END
$36.88 -8AN 150 DEGREE HOSE END
$37.32 -10AN 150 DEGREE HOSE END
$165.22 -6AN AQP STAINLESS STEEL HOSE 20 FEET
$204.07 -8AN AQP STAINLESS STEEL HOSE 20 FEET
$232.74 -10AN AQP STAINLESS STEEL HOSE 20 FEET
Aeroquip Straight Reusable Fitting for use with stainless steel braided hose
Reusable Steel Swivel S.A.E. 37degree (JIC/AN) with aluminum socket. Black anodized.
Eaton's Aeroquip Performance Products anodized aluminum fittings are engineered to match Aeroquip hose tolerances, providing matchless performance. The smooth tube design allows excellent fluid flow. Their compression-style design provides simple, troublefree assembly.
Reusable Aluminum Fittings Features:
- Approved hose styles: AQP Stainless Steel Racing Hose and StartLite Racing Hose
- One-piece design, which allows for improved flow, eliminates two leak points (brazed joints) and significantly improved appearance
- Designed to be re-used without damage to the fitting
- Easier to install than cutter styles, more user friendly.
- Nipple pilot prevents damage to the inner tube
- No seal is broken between nipple and tube when swiveled due to nipple design; ensuring integrity of the seal
- Compression style specifically designed for performance applications
- Wide range of applications
Let me know if you have any questions, or would like to place an order. As always I am here to help,
Erik Johnson
The Race Line
(970) 344-7761 phone
- You may not post replies
- You may not edit your posts
Forum Rules
