8
31
Frank818
Wow the floor is on already. Moving fast! Will you have issues fitting the seat mounts if the floor is fixed? I think some others sweat for a while just cuz the floor was limiting access.
About fuel, I may change my forecast setup and thought of a Walbro. You are replacing the in-tank OEM pump with the Walbro and that's it? Walbro will fit in-tank? Basically, it's a straight swap, no special brackets or mods required?
Oh boy, I hope not! The manual has the seats after the floor IIRC so it shouldn't be that big a deal? It's a Kirkey so it's kinda small and open. We'll find out!
Yes. They're very good pumps and definitely necessary for motors like mine! It is a little longer with a slightly bigger filter (much more flow so more filter area) so it's kinda tricky to fit in. But it mounts the same way and is wired the same way. I recommend one!
