rcotner
I had planned on using wheel offsets as opposed to traditional spacers with long lugs. The offsets are centered on the hub (supported by the hub) and bolt to the axle lugs, then bolt to the wheel with lugs pressed into the spacer. Pretty common if off road application with huge tires. I purchased my kit in two stages so I still don't have the body (next week I hope). I will be able to tell then if I need to space the wheels out. I don't know the backspace or offset. These are factory five wheels and I don't see any of those details in my documentation.
That sounds better than what I was thinking. To give you an idea where the body will be there are two small body mounting tabs welded to your frame right above the rear axle. The wheelwell will end about 3/8 inches or so from those tabs.
