0
0
AJW Performance's Killer B Oil Pickup, Baffle, Oil Pans, Headers and MORE!
Hello everyone! Here at AJW Performance some of our favorite Subaru parts are produced by Killer B! We've enjoyed their products for years and have them on all of our shop subarus and we want you folks with 818 builds to enjoy them as well! Their Oil Pickup is one of THE BEST on the market and is important when it comes to fixing the weak OEM oil pickup! Please see below for some of the products they offer!
The Killer B Holy Headers:
What can be expected from Killer B Holy Headers?
· Improved throttle and Boost Response
· Customers report +25wtq and +25whp on average
· More Consistent EGTs across all cylinders
· More Power Higher into the Rev range
· Improved Fuel Efficiency
· Perfect fit! (some WRX models may requite OEM Oil Cooler to be rotated)
The Subaru Killer B ULTIMATE Oil Pickup!
We have all heard the horror stories. You’re just driving down the road minding your own business and then boom your engine blows without warning.
This ULTIMATE OIL PICKUP uses a .12” thick double bracket, 3X OEM oil pickup tube thickness and a brace between bracket and oil pickup tube to further strengthen the assembly. This is a super duty, engineered solution. No other vendor has anything this rugged available, although I’m sure it will be copied. You asked for it, so here it is. Fits all EJ25 motors
The Subaru WRX/STi High Performance Baffle and Windage Tray:
Features and Advantages of the Killer B Motorsport Windage Tray / Baffle over the OEM piece.
• Closed rear section to prevent oil from sloshing into the crank under hard acceleration and aggressive shifts.
• Block contoured profile to minimize oil returning from the heads interfering with the crank.
• Directional louvers prevent oil in the pan from splash/sloshing into the crank.
• Low profile design to control windage and strip oil from the crank immediately to reduce oil “roping” on the crank.
• Improved oil entry to the pan/pickup to help prevent oil starvation.
• Made from stainless steel for long life, durability and corrosion resistance.
Features and Advantages of the Killer B Motorsport Windage Tray / Baffle over other aftermarket baffles.
• Uses OEM baffle mounting locations
• Not a sandwich between pan & block design that is difficult to install and more prone to leak.
• No rubber parts that can sag and stay open after repeated heat cycling.
• Not Holy Cow expensive!
So what’s all this mean? It means more power due to the reduction in oil interfering with the rotation of the crank and allowing it to spin more freely. Unless it’s in the bearings, anytime oil comes in contact with the cranks or connecting rods it robs power. Reduction of oil splashing and beating off crank & connecting rods will also lower oil temperatures.
Subaru WRX/STi EJ25 Optimal Oil Pan:
Our V2 Performance Oil pan is designed to reliably meet the demands of high performance Subaru Engines used on street or track applications. Oil Pan holds an extra 1.4 quarts of oil, +30% increase in capacity over OEM. Optimal Oil Pan was designed to work with our Ultimate Oil Pickup (OEM ones are known to break), but can be modified to work with the OEM pickup.
3D CAD Designed
· 1/8” thick CNC Laser cut pan
· CNC Formed
· TIG Welded
· (1) OEM Port & (1) 1/2” NPT Port (Plugs or Adapters Required
· Comes with ALL Mounting Hardware
· All Pans Fit and Leak Tested
· No Moving Parts
· Fits Most Headers
· Over 30% Increase in Capacity
· Streamlined Flow-Through Baffles
· Powder Coat Finish Available
· Retains OEM Dipstick
Please visit Killer B's website for other awesome parts that we can provide you folks! Remember, please PM us for optimal pricing!
http://www.killerbmotorsport.com/ind.../PartsList.htm
