My Dad and I just finished laying out our dieted wiring harness in our car and connected the last of the grounds this morning. When we connected the positive terminal to the battery (with the key out of the ignition) the dash comes to life and the idiot lights turn on? Also several of the relays turn on as well (main relay, ignition relay and fuel relay). I’m also getting around 4 volts out of the front driving light harness and about ten volts at the rear tail light harness? The only thing that seems to work properly is the front and rear turn signals but they are working with the key out of the ignition so maybe properly isn't totally correct.
It doesn’t seem to make any difference with the key in or out of the ignition or if the ignition switch is turned onto accessories 1, 2 or start. As long as the battery is connected then everything listed above is on?
We re-checked the grounds and looked for a short and couldn’t find any. Made sure all the connectors are pushed in (only the waste gate solenoid is disconnected)The one positive is we haven’t blown any fuses or shorted out any wires.
Our donor was a 2002 WRX and we removed through the diet ABS, Airbags, Cruise, HVAC, Security, and Radio. We took out time, used the 2002 WRX wiring diagram and were careful throughout the process and when removing the sub systems never cutting farther if there was a tee in place in the harness. That way hoping we wouldn’t disturb another system that might be intertwined.
Anyone have a suggestion or offer some help? We could use a little.
