David,
The 4.6L 3V is close in design to the Coyote. I've got A/C and P/S on the front of my 2010 Mustang engine and the only mod I had to do (so far) was cut the steering shaft and move the lower u-joint back to clear the P/S pulley. Is the front of the Coyote that different?
The problem I'm now trying figure out is how to fit the Ford Racing air filter/MAF assembly into the engine bay. It's too big and angles far left. I imagine finding some shorter pieces will work, but then does that mess up what the computer expects from the MAF?
