Will the Tilton work with the manual brake setup ? One for sale on the other forum. Thanks
Not sure, but I think some of the Tilton MC's have the same bolt patern as Wilwood. You might need to check with Tilton, or get some measurements from the seller.
Bill,
Here's the information you need to check.
http://www.tiltonracing.com/pdfs/72-602_web.pdf
http://www.wilwood.com/PDF/DataSheets/ds761.pdf
Looks like they both have the same mounting locations. HTH
Hank
“If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
