Results 1 to 10 of 10
Thread: 2006 front aluminum control arm cleanung
    Virginia
    MY 2006 WRX aluminum control arms were covered with both a black paint, and a oily like substance making it difficult to soda blast.
    My salutation was to spray "aircraft paint remover", in the spray can. and than Brillo pad the entire unit.
    Tip for using the paint remover, the directions said to spray and let stand for 15 to 30 minuets. I sprayed it on and left it for about 10 to 15 minuets and
    removed the paint residue with paper towels and than repeated the process. After witch I rinsed them off in the sink, and used a Brillo pad to further clean the services.This process cleaned about 95% of the problem areas. A WORD OF ADVICE - WEAR RUBBER GLOVES. grayghost
    Fresno, CA
    I have a HF blast cabinet and use glass beads for all of my aluminum cleaning. So far I have cleaned two sets of control arms for 818 builders and I believe that the owners are happy with the results. I do not like caustic paint removers for the reason you mention.
    Doug
    Carrollton, Ga.
    Quote Originally Posted by 68GT500MAN View Post
    Doug
    Ditto re: effectiveness of glass bead blasting. My LCAs were just like you describe.
    Bill
    Senior Member AZPete's Avatar
    My aluminum LCAs cleaned up nicely on a wire wheel.
    Nepa
    Instead of starting another thread I figure this question fits in here. What ball joint is used with the aluminum arms. I have 06 wrx arms but the ball joints that I purchased are too long and the bolt won't tighten. Maybe it's the taper and not length? Anyway I purchased mevotech mk9513 that's the part number listed. Buts it's also the number for 05 steal arms? Any help would be appreciated
    The aluminum arms have a collar between the ball joint and the arm.
    Freeport, ME
    Quote Originally Posted by Jaime View Post
    and the same ball joint...
    Dan
    Nepa
    Mine didn't come with a collar. Any pics. Something that shoulda come with the ball joint? Thx
    Nepa
    The part is subaru part 20216FA000. If anybody else needs them
    Nov 2012
    Medina, OH
    To go along with the part number, it's the black, conical thing on the ball joint studs.
    Rich
