I know the Boyd tank comes with a fuel pump but it has some other options like a sender and rollover valve. Will the Subaru parts work/fit (sender and vent valve). Also does the fill tube still fit the same or does it need to be modified? Will you still use the fuel pump controller on the Boyd pump?
