Results 1 to 5 of 5
Thread: Fuel requirements for LS3 motor.
    Jun 2014
    I am helping a friend build a 33 HotRod. We are using a fuel injected LS3 motor. I don't know what fuel pump and regulator I need. I would to use an in-tank pump, but I don't want cut my tank open to install it. So, My question is what is the best set-up for this system. Also, does the return line come from the regulator or the fuel rail.
    Thanks for any help you guys can provide.
    Larry
    Senior Member OCCPete's Avatar
    Dayton, OH
    LS3 needs 60 psi and is a "returnless" system, meaning the return line comes from the regulator. There are many options for fuel pump and regulator. I'm using a Walbro 392 pump and a LS1 fuel filter/regulator: http://www.speedwaymotors.com/LS1-Fu...Kit,41791.html.
    Pete
    Catonsville, Maryland
    Quote Originally Posted by Larry View Post
    Larry
    Larry See if this would meet you needs http://www.streetlegaltv.com/tech-st...-installation/
    Ron
    Mar 2013
    Long Island NY
    Nice article.
    Be careful installing with LS3. It's only rated at 43.5 psi.
    Jun 2014
    I think I'm going to use the Walbro 392 pump. That in tank pump is a little to pricey.
    Thanks for the help, Larry
